Rollback bar
- Maha Nadarasa
- x 51
- x 48
Rollback bar
Blue rollback bar became white and cease to move. What is the reason?
Model Break View is on. Turn it off, and it works.
Go to full post- AlexLachance
- x 2296
- x 1971
Re: Rollback bar
Restarting doesn't fix the issue? I've never seen this before from what I recall
Maybe you have this unchecked? Doubt it's the case because I couldn't get it to turn grey
Re: Rollback bar
I don't see a freeze bar. Is your freeze bar pulled all the way down? Is it activated in the settings? s the part used in-context somewhere, or is it inserted into another part? I think this can happen if you are also editing it in the context of an assembly, and then opened it in its own window too.
- Maha Nadarasa
- x 51
- x 48
Re: Rollback bar
Rebooting the computer is impossible now because many files are opened.
- x 2296
- x 1971
Re: Rollback bar
IMHO, it is one of those things where SolidWorks loaded it's memory and now is causing random issues. Try saving all, closing SolidWorks, reopen SolidWorks, reopen problematic file or having a collegue open the same file and see if he has the same issue. If it's repeatable across multiple workstations then it most likely is file related.Maha Nadarasa wrote: ↑Tue Apr 27, 2021 3:19 pm Rebooting the computer is impossible now because many files are opened.
- Maha Nadarasa
- x 51
- x 48
Re: Rollback bar
@AlexLachance
No problem with other files therefore not sure rebooting will work. It is a very old file. I am in the process of checking it and deleting it from the system. File is attached (SWX 2020v).
- P94 - T-Joint.SLDPRT
- (106.94 KiB) Downloaded 56 times
- x 1231
Re: Rollback bar
- x 2296
- x 1971
Re: Rollback bar
Most likely won't work then as you stated. Perhaps it is a little corruption that happened over time.Maha Nadarasa wrote: ↑Tue Apr 27, 2021 3:31 pm @AlexLachance
The part does not seem too complex, you could try copy/pasting the features from that part to a new one and see if the new one is fine. If it is, you could overwrite the old one and most references would not be lost as far as I'm aware.
Edit: Looks like Mr. Miller has figured out the issue!
- Maha Nadarasa
- x 51
- x 48
Re: Rollback bar
@mike miller
Thanks
Thanks
Re: Rollback bar
Model Break View? I have to admit, I've never heard of Model Break View before. That Solid Edge sabbatical took its toll! Good job @mike miller !
