Failing mates
Uncle_Hairball
x 27
x 90
Failing mates
Over and over again, I have a stable assembly model with no red or yellow mates. I save and close and the next time I open the model, it turns red. Any thoughts as to why this would be happening? I'm on SW 2019.
zxys001
x 2272
x 979
Re: Failing mates
Unread post by zxys001 »
Uncle_Hairball wrote: Wed Apr 28, 2021 12:22 pm Over and over again, I have a stable assembly model with no red or yellow mates. I save and close and the next time I open the model, it turns red. Any thoughts as to why this would be happening? I'm on SW 2019.
Hello Uncle Hairball (great name!)
1 - Any imported geometry?
2 - Relative small/large features (.001mm and 1000mm)
3 - VOR (verification on rebuild) On/Off?
4 - Configs?
5 - rebuilding via Incontext relations or CRC's?
mike miller
x 1070
x 1232
Re: Failing mates
Unread post by mike miller »
Where are the errors and what do they say? I haven't used my crystal ball for awhile.
Is it a lost mate reference, an overdefined condition, or a failed external reference...or...???? It's an absolute shot in the dark without knowing more details.
Answers: 13
x 2066
x 1731
Re: Failing mates
Too many mates in a single assembly/sub-assembly is another possibility. The solidworks mate solver runs out of fingers and toes rather quickly. After that, it becomes inconsistent.
Parallel mates also tend to cause lots of problems.
Roasted By John
x 268
x 583
Re: Failing mates
Multiple mates doing the same thing, how many times have I forgotten that I mated those parts before??
First off, I would delete all the mates and start over, I can't stand assemblies that act like that, drives me nuts, good when you save and then forest fire when you open, definitely a "Delete The Mates" candidate.
You really don't need to delete all of them, I normally start from the bottom and go up, delete a section, close and re-open the file.
To reduce the amount of mates, look for perpendicular possibilities, two mates instead of three is a plus by subtraction ;)
www.martinsroastapig.com
Pig Roast Your Way
MJuric
x 873
Re: Failing mates
Unread post by MJuric »
One of the things I absolutely abhor about SW. It seems to randomly decide which mates are higher up in the hierarchy and thus causing, randomly, mate errors. Then to make matters worse rather than having any ability to narrow down where the problem is it simply throws up it's hands and proclaims "EVERYTHING IS BROKEN!".
I had an assembly that would randomly flip the direction of a shaft once. No errors no yellow, red...shaft going one way, then the next time you looked, shaft is going the other way. It was maddening.
As others have noted the culprits are often times conflicting mates, duplicate mates and the worst offender is angle mates.
Uncle_Hairball
x 27
x 90
Re: Failing mates
zxys001 wrote: Wed Apr 28, 2021 12:39 pm Hello Uncle Hairball (great name!)
None
No
On
4 - Configs?
Sometimes
No in context relations. What's a CRC?
Uncle_Hairball
x 27
x 90
Re: Failing mates
mike miller wrote: Wed Apr 28, 2021 1:02 pm Where are the errors and what do they say? I haven't used my crystal ball for awhile.
The problem I'm trying to resolve is not the errors; rather, I'm trying to figure out why the assembly goes from resolved to corrupt just because it took a nap overnight. The errors are conflicting mates or over constrained assemblies.
Uncle_Hairball
x 27
x 90
Re: Failing mates
Uncle_Hairball wrote: Wed Apr 28, 2021 2:23 pm The problem I'm trying to resolve is not the errors; rather, I'm trying to figure out why the assembly goes from resolved to corrupt just because it took a nap overnight. The errors are conflicting mates or over constrained assemblies.
Maybe I should clarify a little: The assembly was good last night (it's not just one assembly, it's a recurring problem with many assemblies), today it is not. I am the only SW user unless China is hacking my files. Nothing has been done to the parts or assemblies. All I did was go home, have dinner, sleep a little, come back, and open the file. Kaboom!
mike miller
x 1070
x 1232
Re: Failing mates
Do they go away with a Ctrl+Shift+Q?
Are there mates to Sheet Metal parts? I've had face IDs switch randomly after a bad night's sleep(?). This will cause conflicting mate conditions that can be difficult to find. The What's Wrong dialog is your best friend in a case like this.
x 1168
x 2304
Re: Failing mates
SolidWorks plays fast and loose with a lot of things. One way you might normally think of a "fully defined part" as having 3 plane-to-plane coincident relations, and SW lets you do that, and trains people to do that.
Degree of Freedom analysis
- 1 X to X plane coincident mates locks down 1 translation (in X - translation in Y and Z are open) and 2 rotation (about Y and Z - rotation about X is open)
- 2nd plane Y to Y plane locks down translation in Y, Z still open), rotation in X and Z are locked, Z is double locked, no rotation open)
- 3rd Z to Z plane locks down translation in Z, all closed. Locks rotation in X and Y, both double locked.
So your standard 3 plane coincident scheme leaves you with 3 overdefined degrees of freedom, but SW somehow allows it... sometimes. And then suddenly it doesn't.
Instead of 3 coincident plane mates, you could use 2 line-to-line mates, which locks everything down, but still has 1 overdefined dof.
If you think of mates as constraining degrees of freedom, you are less likely to overdefine your mates, and can stop relying on SW to to allow some and not others as it sees fit.
x 2198
x 1900
Re: Failing mates
Oh, I know I know!
You use flexible assemblies. Remove the flexible and put it back. For some reason when you restart SolidWorks, it doesn't remember the flexibility of the assembly and therefor throws those error. Removing it and putting it back on refreshes it's memory. SolidDoofy
Answers: 13
x 2066
x 1731
Re: Failing mates
My problems weren't really about over-defining the mates, but more about overwhelming the system.
Old way
1 assembly with 100 parts
New way
1 assembly with 10 sub assemblies, each with their own sub assemblies as needed.
Old way
100 fasteners
New way
1 fastener and component patterns
Old way
Mate as the machine would be built
New way
Use ordinate geometry as much as possible.
Solidworks has to simultaneously solve all mates in a given assembly. It has a much higher chance of success of solving 10 individual assemblies with 10 mates vs 1 assembly with 100 mates. (Even if all of those smaller assemblies come together in the main assembly, they are solved one at a time.) Hopefully I've done a decent job of explaining this.
Uncle_Hairball
x 27
x 90
Re: Failing mates
mike miller wrote: Wed Apr 28, 2021 2:35 pm Do they go away with a Ctrl+Shift+Q?
I wish, but no.
No sheetmetal in this case.
Uncle_Hairball
x 27
x 90
Re: Failing mates
matt wrote: Wed Apr 28, 2021 2:42 pm SolidWorks plays fast and loose with a lot of things. One way you might normally think of a "fully defined part" as having 3 plane-to-plane coincident relations, and SW lets you do that, and trains people to do that.
Interesting... I am very careful not to overconstrain, but your explanation has made me realize that my typical method has too many rotation constraints. I'll have to reconsider.
Uncle_Hairball
x 27
x 90
Re: Failing mates
AlexLachance wrote: Wed Apr 28, 2021 2:46 pm Oh, I know I know!
Yes, I've seen that, too.
Uncle_Hairball
x 27
x 90
Re: Failing mates
SPerman wrote: Wed Apr 28, 2021 2:52 pm My problems weren't really about over-defining the mates, but more about overwhelming the system.
Old way
New way
Old way
100 fasteners
New way
Old way
New way
Understood and I agree. That's the way I usually do things.
DennisD
x 999
x 1434
Re: Failing mates
Unread post by DennisD »
Old way
New way
Old way
100 fasteners
New way
Old way
New way
These are good tips. Subassemblies in particular are good, especially if you can put as many things in the subs as possible.
Also, sometimes if the subassembly is a purchased group of parts or otherwise can be static then you can locate them with mates and then Fix everything and then suppress the mates. THIS really helps!
Assembly patterns are also very good. Keep in mind that the pattern instances can reference different configurations of the subassemblies.
- - -Randy Pausch
Roasted By John
x 268
x 583
Re: Failing mates
Uncle_Hairball wrote: Wed Apr 28, 2021 2:29 pm sleep a little, come back, and open the file. Kaboom!
It's the loss of sleep, which could be directly related to overseeing anything till it's way too late, using SW sometimes give us "Day Mares" which reduces the ability's for the 2:00 snooze we all need, dream on, yep that don't happen in Fusion 360, neither does anything else, hhhh
BTW - Best Forum Name Ever ;) :) :0
Pig Roast Your Way
TRKemp
x 33
Re: Failing mates
Unread post by TRKemp »
Likely not your issue, but the only time i have issued with this occurring is when my assembly opens in Large Assembly Mode. Usually i can correct it by resolving everything.. etc.. but instead I mostly just close it and open it resolved.
Also, if I have a part or sub-assembly that was working just fine but then gives me mate errors, I always try just suppressing and unsuppressing it before messing with any mates. More often then not it right's itself, albeit inexplicably ... but that's SW for you.
MJuric
x 873
Re: Failing mates
Old way
New way
Old way
100 fasteners
New way
Old way
New way
Absolutely agree that the least complex you can make an assembly the better. I try to make S/A's simple, if possible and mate them in their parent by the base level planes and origins. This kind of sucks because it requires that all the S/A be designing in machine position. This also can't be done when you have moving S/A so they have to be mated the way they are built or to the item they are not moving in relationship to.
Damo
x 146
x 190
Re: Failing mates
Unread post by Damo »
MJuric wrote: Wed Apr 28, 2021 1:45 pm One of the things I absolutely abhor about SW. It seems to randomly decide which mates are higher up in the hierarchy and thus causing, randomly, mate errors. Then to make matters worse rather than having any ability to narrow down where the problem is it simply throws up it's hands and proclaims "EVERYTHING IS BROKEN!".
I'll second this.. and add that Tangent mates also have frequently caused me no end of grief until finally throwing my arms in the air and deleting them and creating other reference geometry to enable a more stable coincident mate instead.
And, YES..! It can literally take only one "flipped mate" to throw up a swathe of errors across the entire mate folder
Answers: 22
x 1659
x 2060
Re: Failing mates
It's not particularly uncommon that I get mate errors on an Assembly that previously didn't have any, so I suppress one of the mates. The errors go away. I un-suppress the same mate. No errors.
Uncle_Hairball
x 27
x 90
Re: Failing mates
Roasted By John wrote: Wed Apr 28, 2021 3:20 pm It's the loss of sleep, which could be directly related to overseeing anything till it's way too late, using SW sometimes give us "Day Mares" which reduces the ability's for the 2:00 snooze we all need, dream on, yep that don't happen in Fusion 360, neither does anything else, hhhh
Thanks! Hairball was given to me by my fraternity brothers and Uncle was given by my sister when she made me an uncle.
Roasted By John
x 268
x 583
Re: Failing mates
Uncle_Hairball wrote: Thu Apr 29, 2021 1:12 pm Thanks! Hairball was given to me by my fraternity brothers
That's enough on the Hairball comment, seems to be a lot more then we wanna know behind that nickname, oh boy () :shock: :roll: :lol:
Pig Roast Your Way
Ry-guy
x 38
x 139
Re: Failing mates
Unread post by Ry-guy »
Crap. I thought this thread was about Failing dates. I've had a lot of those in the past. Not nearly as many failed mates though!
Damo
x 146
x 190
Re: Failing mates
Glenn Schroeder wrote: Thu Apr 29, 2021 7:05 am It's not particularly uncommon that I get mate errors on an Assembly that previously didn't have any, so I suppress one of the mates. The errors go away. I un-suppress the same mate. No errors.
Oh YES..!! This too. In actual fact, that is my "Go-to" method of dealing with any sudden and inexplicable forest fires in the feature tree.
Find the first RED broken mate and supress and unsurpress. Presto, fire is out.. I guess SW just gets overwhelmed or confused sometimes..
It took me a while to work this out too. The number of times I've wasted time chasing down conflicting mates to find nothing wrong and it all just suddenly works again. o[
x 1168
x 2304
Re: Failing mates
I had a run in with not failing mates, but flipping mates. This may be an old story for some of you, but when I was working on an engine assembly for some training materials, I absolutely could not get the Cam mates to stay where I put them. I assembled an 8 cylinder engine with all of the moving parts for overhead cams and valve lifters, and as it would go through the motion, one or two of the followers would just instantly flip.
This gif shows what's going on. The assembly was built originally in 2012, and then updated in 2018, and now checked in 2020, and it's still doing the same thing. You may have to click the image to get it to play. Larger gifs get a thumbnail which isn't animated.
To me its kind of remarkable that the software can handle the 281 top level mates and 272 flexible subassembly mates it takes to make this go, but why it always has to flip some of them after they've been working just blows me away.
Answers: 22
x 1659
x 2060
Re: Failing mates
I had a profile mate between two rectangular faces that would randomly rotate one of the components 90° when I wasn't looking. That was fun.
Jaylin Hochstetler
x 379
x 355
Re: Failing mates
Glenn Schroeder wrote: Fri Apr 30, 2021 10:56 am I had a profile mate between two rectangular faces that would randomly rotate one of the components 90° when I wasn't looking. That was fun.
I've had that too! Did you ever find a remedy? SolidSometimesWorks!
Answers: 22
x 1659
x 2060
Re: Failing mates
Jaylin Hochstetler wrote: Tue May 04, 2021 8:22 am I've had that too! Did you ever find a remedy? SolidSometimesWorks!
No, but I don't believe I've used a profile mate on rectangular surfaces since then either. I typically use them for mating hardware in holes.
Jaylin Hochstetler
x 379
x 355
Re: Failing mates
Glenn Schroeder wrote: Tue May 04, 2021 8:31 am No, but I don't believe I've used a profile mate on rectangular surfaces since then either. I typically use them for mating hardware in holes.
I also use it for hardware. I have a macro for it w/ a button for it on one of my mouse gestures. It locks the rotation, and enters 0" for the distance. The only problem is it won't always get the alignment right. The macro is in the downloads under Mike Miller's macros.
x 2488
x 1894
Re: Failing mates
matt wrote: Fri Apr 30, 2021 10:17 am I had a run in with not failing mates, but flipping mates. This may be an old story for some of you, but when I was working on an engine assembly for some training materials, I absolutely could not get the Cam mates to stay where I put them. I assembled an 8 cylinder engine with all of the moving parts for overhead cams and valve lifters, and as it would go through the motion, one or two of the followers would just instantly flip.
So @matt,
There was a whole thread about flipping mates over in the old forum. Just out of curiosity does this type of thing happen with SE? If not, how do they handle it that the SW people can't figure out?
x 1168
x 2304
Re: Failing mates
mattpeneguy wrote: Tue May 04, 2021 9:30 am So @matt,
I only made a 2 cylinder engine in SE, and I don't think I had the same kind of problems. The mate solving is not a Parasolid function, and I do think they use different components to solve mates.
Answers: 24
x 757
x 910
Re: Failing mates
The problem is, when a mate has 2 (or more) possible solutions, when Solidworks is rebuilding, it can "jump" to one of the possible solutions, which may or may not be the solution you wanted.
I understand it......but not necessarily like it.
The only solution is to make sure that there is only 1 solution.
Example: Tangent mates are notorious for flipping to the other side of the circle because, mathematically, it is a valid solution.
The solution is to eliminate all other possibilities. Like use some sketch geometry to create a line with an end point where you want your tangency. Now make your tangent line coincident with the end of the line.
Tom G
x 999
x 468
Re: Failing mates
Unread post by Tom G »
Roasted By John wrote: Wed Apr 28, 2021 1:29 pm To reduce the amount of mates, look for perpendicular possibilities, two mates instead of three is a plus by subtraction ;)
Yuck!
Sorry to join this topic after it's been eviscerated clean.
I only wanted to chime in that Perpendicular mates cannot flip when you want them to. I prefer the extra control that Parallel allows.
That said, I also have begun making a redundant alternate (Front-like) Plane, for example, and I call it Accessible Plane. This way, I can orient my ball valve stems (and handles) to that plane, and if I wanted to flip which side is more accessible, I flip the reference plane and they all follow.
x 2488
x 1894
Re: Failing mates
dpihlaja wrote: Tue May 04, 2021 11:54 am The problem is, when a mate has 2 (or more) possible solutions, when Solidworks is rebuilding, it can "jump" to one of the possible solutions, which may or may not be the solution you wanted.
I get it too Dan. But, what does SE and IV do to prevent this or, do both of them have the same problems?
Do SE and IV "know" proximity to where the initial mate is made and not make the mistake?
I wonder if SW didn't create the situation with their choices and whether the other guys were smarter and understood and planned to avoid this situation?
Answers: 24
x 757
x 910
Re: Failing mates
mattpeneguy wrote: Tue May 04, 2021 12:43 pm I get it too Dan. But, what does SE and IV do to prevent this or, do both of them have the same problems?
I have seen the issue (to a lesser extent) in CATIA V5.
I know that I saw the issue in I-DEAS.
Answers: 13
x 2066
x 1731
Re: Failing mates
I don't recall every having this problem in NX.
