Did I miss a memo?
There used to be the possibility to get 'write access' when working on a PRT or ASM that someone else had open by just doing a RMB and selecting it out of the pop up.
Am I losing it?
Did I imagine it?
Should I see to up my meds?
Get write access
- Peter De Vlieger
- x 223
- x 105
- x 2364
- x 2013
Re: Get write access
No you're correct, there are instances of selections that makes it that do not show up, but it should generally show.Peter De Vlieger wrote: ↑Fri May 07, 2021 8:44 am Did I miss a memo?
Am I losing it?
Did I imagine it?
Have you looked if it was hidden unintentionally or by a SolidWorks bug?
- Peter De Vlieger
- x 223
- x 105
- x 2364
- x 2013
Glad I could be of helpPeter De Vlieger wrote: ↑Fri May 07, 2021 9:08 am Cheers Alex.
Of course now that I posted about it, it shows up
Hi @Peter De Vlieger
I believe this is where you turn it on/off
System Options > Collaboration > Enable multi-user environment > Add shortcut menu items...
- Peter De Vlieger
- x 223
- x 105
Ron,
That is right.
However I never change that setting so there for, silly ol' me, I expect it to work.
That is right.
