Extend up to Surface not work
- Maha Nadarasa
- x 51
- x 48
All are surface in this video shows. I want to extend the flat surface up to the circular surface but extend up to surface does not work. How to fix it?
- Extend Surface.zip
- (3.13 MiB) Downloaded 61 times
- x 1211
- x 1998
Re: Extend up to Surface not work
Can you attach the file? I tried roughly recreating what you have and it works fine for me. 2021 sp3.
- x 2489
- x 1899
@Maha Nadarasa,
I'm not sure from your picture, but I may know what's going on.
What you are extending up to the surface has to fall within the bounds of the surface. If you are trying to extrude up to a flat surface, you can use a plane instead because planes are infinite. But, SW correctly chooses not to extrapolate outside of the surface you are extruding up to.
Does that make sense?
Here's a video showing how SW correctly chooses to have the feature fail after I edit it (you probably have to click on it for it to play):
- x 1211
- x 1998
@mattpeneguy Unless 2021 enhanced this feature, it works when its not intersecting.
- x 2489
- x 1899
Wow, you are right. If the surface is planar it works.jcapriotti wrote: ↑Sat May 08, 2021 5:19 pm @mattpeneguy Unless 2021 enhanced this feature, it works when its not intersecting.
@Maha Nadarasa,
Can you post a video or your part of what exactly is failing, because your picture shows it working, right?
- Maha Nadarasa
- x 51
- x 48
Here is part file (2020v). By using Multiple Trim I proceed but I want to know why extended up to surface does not work for this particular part. I tried extended up to surface separately but it worked.
- Piston Rod1(issue).SLDPRT
- (186.91 KiB) Downloaded 32 times
