Part Reviewer
Maha Nadarasa
x 51
x 48
Part Reviewer
I am not familiar with Part Reviewer. This is a simple part to test the Part Reviewer window but it is blank. How to activate it?
PartABC-1.SLDPRT
(1.83 MiB) Downloaded 91 times
x 1614
x 1455
Re: Part Reviewer
It let you add comments on each feature.
Its blank because there is no comment in your part.
No, it does not show the part.
Maha Nadarasa
x 51
x 48
Re: Part Reviewer
I usually use Design Builder to add comment about part. This seem you have to add comment somewhere and this window will show it. Because this window will not take any text format.
Merovingien
Re: Part Reviewer
Unread post by Merovingien »
it can be used to analyse step-by-step "how a dude create part, the technics he used, or the dumbiness he used"
Maha Nadarasa
x 51
x 48
Re: Part Reviewer
@Merovingien
Thanks for the link. It help me to clarify the issue.
Maha Nadarasa
x 51
x 48
Re: Part Reviewer
In my graphic area top pan is missing. How to fix it?
Merovingien
Re: Part Reviewer
is the PRT "new" ? that mean "design tree empty" ?
Part Reviewer need "a tree"
if PRT not empty, maybe are part of the "Beta-Tester of SW2021"
or maybe it's some install-problem with your computer.
Maha Nadarasa
x 51
x 48
Re: Part Reviewer
Not empty. I attach my file (2020v). You can try. My SWX is a standard version.
Pattern on a Curved Surface.SLDPRT
(44.54 MiB) Downloaded 77 times
Merovingien
Re: Part Reviewer
i didn't use 2020, i'm under (SW2021 and 2021 too much problem, as usual)
maybe someone else can try
Maha Nadarasa
x 51
x 48
Re: Part Reviewer
I have 2021v SP2, I use this to open other file if it is 2021v. I nerve use 2021v for my purpose because I have a bitter experience with previous versions with lower SP.
Maha Nadarasa
x 51
x 48
Re: Part Reviewer
It is coming with previous version.
Ömür Tokman
x 987
x 342
Re: Part Reviewer
Unread post by Ömür Tokman »
Maha Nadarasa wrote: Wed May 26, 2021 5:43 am Not empty. I attach my file (2020v). You can try. My SWX is a standard version.
Hi @Maha Nadarasa
Why is his MB so high?
I know you can draw it simply.
Maha Nadarasa
x 51
x 48
Re: Part Reviewer
@ Ömür Tokman
I replicate the YouTube example. I will entertain it, If you can simplify it.
x 1614
x 1455
Re: Part Reviewer
Works in 2021 SP3
Maha Nadarasa
x 51
x 48
Re: Part Reviewer
I had 2021 SP2 but I uninstalled it because of the following reason.
viewtopic.php?f=3&t=609
sergio.monti
x 48
x 21
Re: Part Reviewer
Unread post by sergio.monti »
Maha Nadarasa wrote: Wed May 26, 2021 5:21 am In my graphic area top pan is missing. How to fix it?
I'm on 2020 SP5 and I have the same issue. I can't get the top pan.
