File name issue while saving solid bodies
christian chu
x 39
Unread post by christian chu »
Not happened all the time, I got this mesg (see att. image) once a while while saving solid bodies to external files (no matter what name I tried) - "Shutdown and reopen SW" would solve the issue. Not sure why it happens
Is it the SW issue or I'm doing something wrong
Thanks
x 1562
x 1406
Re: File name issue while saving solid bodies
Looks like it cannot use the body name as filename.
Got () [] {} in the name? Or other @#$%*&?
LOL ( ) ()
Lapuo
x 176
x 106
Unread post by Lapuo »
This is SW issue i believe.
Sometimes it happens to me (randomly) and after SW restart it fixes it self :D
mike miller
x 1070
x 1232
Unread post by mike miller »
You need to quit swearing when typing in file names.
Windows transliterates......and we have a problem. No, no, you can't hide your bad habits from us. :D
mbiasotti
x 41
Unread post by mbiasotti »
I've seen this issue also (and regularly) and agree with @christian chu that I need to close shutdown and restart SW to rid the problem. SW must be cache the filename somewhere and not clear until the program restarts...
RichGergely
x 103
x 140
Unread post by RichGergely »
If I remember correctly, if you run in administration mode it won't happen. I don't use the feature for other reasons now but I'm pretty sure that was a fix so it didn't happen.
christian chu
x 39
RichGergely wrote: Sun Jun 06, 2021 10:33 pm If I remember correctly, if you run in administration mode it won't happen. I don't use the feature for other reasons now but I'm pretty sure that was a fix so it didn't happen.
I always run SW as Administration
RichGergely
x 103
x 140
Actually run the program as administrator or have administration privileges?
Every time when you launch solidworks a pop-up will come up and will ask you do you want to make changes to the program.
Right click on icon
Properties
Compatibility
Run program as administrator
x 2213
x 1904
christian chu wrote: Thu Jun 03, 2021 2:08 pm Not happened all the time, I got this mesg (see att. image) once a while while saving solid bodies to external files (no matter what name I tried) - "Shutdown and reopen SW" would solve the issue. Not sure why it happens
Thanks
If a restart fixes the issue, then SW's memory most likely saturated.
RichGergely
x 103
x 140
OK looked up some old threads on this problem and the answer is as I said previous.
You need to run the program in administror mode not just have administration privalages or be a administrator,
Right click on icon
Properties
Compatibility
What's really sad there are threads going back past 2012 and still not fixed.
