[SW PDM Add-in] Prevent Check-in / Create Reference dialogs
- x 288
- x 56
New to PDM API, and am working on a add-in to create custom references to legacy data. Everything seems to be working well, but I want to make the process a little quicker/fluid. Is there a way to prevent the dialog boxes from showing when a file has a newly created a reference?
Can I assume you are checking in from the API? Or does the user initiate the check in then you have an add-in with a hook on before check in that does the custom refs?
The IEdmFile5::UnlockFile() function takes an options flag value. I haven't used this one specifically so I'm not sure which one you want to use. The times I've used flags the jargon is foreign to me so it's a bit of trial and error mixed with web searches on the terms to see what others have done.
http://help.solidworks.com/2019/english ... kFlag.html
hope that's more help than hindrance.
Edit: Sorry, I misunderstood. I thought it was the Reference File Dialog from the check in that was showing up. After a second look at the image I realized its the add custom ref that's showing the RFD. Can you share what code you have? Just looking at the example in the help, I'm wondering if you can try commenting out the .ShowDlg() call, wouldn't need the CreateTree then which is a requisite to ShowDlg(). Not sure this will work though, IIRC I've ran into situations where the next action fails if the ShowDlg is not called.
Go to full postThe IEdmFile5::UnlockFile() function takes an options flag value. I haven't used this one specifically so I'm not sure which one you want to use. The times I've used flags the jargon is foreign to me so it's a bit of trial and error mixed with web searches on the terms to see what others have done.
//Add the file that is copied to the clipboard as a custom reference to the selected file
foreach (int ID in ppoFileIdArray)
addCustRefs.AddReferencesClipboard(ID);
addCustRefs.CreateTree((int)EdmCreateReferenceFlags.Ecrf_Nothing);
addCustRefs.ShowDlg(this.Handle.ToInt32());
retCode = addCustRefs.CreateReferences();
Austin
Re: [SW PDM Add-in] Prevent Check-in / Create Reference dialogs
- x 3
- x 288
- x 56
Thanks for the quick response, Ben. I'm mimicking the portion of this example that adds the custom references.bnemec wrote: ↑Wed Jun 09, 2021 11:24 am Can I assume you are checking in from the API? Or does the user initiate the check in then you have an add-in with a hook on before check in that does the custom refs?
//Add the file that is copied to the clipboard as a custom reference to the selected file foreach (int ID in ppoFileIdArray) { addCustRefs.AddReferencesClipboard(ID); addCustRefs.CreateTree((int)EdmCreateReferenceFlags.Ecrf_Nothing); addCustRefs.ShowDlg(this.Handle.ToInt32()); retCode = addCustRefs.CreateReferences(); }
https://help.solidworks.com/2021/englis ... Redirect=1
I'll fiddle with some dialogs and let you know!
Austin
- x 288
- x 56
Thanks for this resource. I will give it a look! Looks a bit different than mine.Ulf Stockburger wrote: ↑Wed Jun 09, 2021 11:39 am Maybe this will help you. https://github.com/erppdm/SWPAW/tree/ma ... les/Demo09
BiI SAP-PDM
IEdmAddCustomRefs addCustRefs = (IEdmAddCustomRefs)vault.CreateUtility(EdmUtility.EdmUtil_AddCustomRefs);
Int32[] ppoFileIdArray = new Int32[parentFilePaths.Count];
IEdmFile5 file = null;
IEdmFolder5 parentFolder = null;
int i = 0;
foreach (string FileName in parentFilePaths)
file = vault.GetFileFromPath(FileName, out parentFolder);
if (!file.IsLocked)
file.LockFile(parentFolder.ID, poCmd.mlParentWnd, (int)EdmLockFlag.EdmLock_Simple);
ppoFileIdArray[i] = file.ID;
i++;
Boolean retCode = false;
//addCustRefs.ShowDlg(poCmd.mlParentWnd);
// Check in the file
file.UnlockFile(poCmd.mlParentWnd, "Custom reference added");
Austin
- x 288
- x 56
Feeling a bit silly. My code literally tells me what it's doing, and I just glazed over it.
Commented the two dialogs and now they don't show. Maybe I should take a break from debugging...
Thanks again for the suggestion, Ben. Sometimes I have to ask stupid questions to get smart answers.
Marked your suggestion correct as it was the easiest, but I think Ulf's was an excellent suggestion as well. I just am too lazy to implement a different method.
//Display current custom file references
//retCode = addCustRefs.ShowEditReferencesDlg(ref ppoFileIdArray, poCmd.mlParentWnd);
Austin
Those are my lines! Happens more than I want to admit. That's why I have been told about rubber duck debugging buddy.Austin Schukar wrote: ↑Wed Jun 09, 2021 12:04 pm Feeling a bit silly. My code literally tells me what it's doing, and I just glazed over it.
https://en.wikipedia.org/wiki/Rubber_duck_debugging
- x 288
- x 56
LOL. I have not heard of that, but am glad that I now know about it.
Austin
