I had came across a lot situation where i need to change the selection for a mate in SWX...
However, a lot of time, I always had trouble identify which selection is which....
For example, I would like to change this pin from the left cylinder to the right cylinder When edit the mate, I would like to remove the face selection of the left cylinder hole and replace it with the face of the right cylinder hole (while keeping the face selection of the pin)
As a lot of time i am dealing with file name that is purely number (eg: 12345, 12346, 12347), I could not remember what is the file name, hence i am not able to identify and remove the face selection from the property manager. Although solidworks will "darken" the edge of the selected/highlighted mate selection, when the part is "overlapping", it is still very hard to know which part is which...
Take the below image as example, even though solidworks darken the edge, I will not know whether Face<1>@testPart2-1 belongs to the pin or the hole In the end, I will just end up deleting the mate, drag out the part, and readd the mate....
So I was wondering is there a better way to identify and change the mate selection?
