SWX and RMB Menu
Maha Nadarasa
x 51
x 48
SWX and RMB Menu
I couldn't see SWX in my RMB Menu. How to fix it.
zwei
x 185
x 600
Re: SWX and RMB Menu
Unread post by zwei »
This seem like something messed up the registry
Have you try to rename the registry?
https://www.javelin-tech.com/blog/2019/ ... -explorer/
Diaval
x 50
x 110
Unread post by Diaval »
What version of SolidWorks are you using?
In SW 2019 or earlier, these shell integration options are installed with SolidWorks Explorer option in the Installation Manager
In SW 2020 and later, these shell integration options are installed with the SolidWorks File Utilities option in the Installation Manager
You can check your installation to see if you have the proper option installed to get the RMB context menu options. If they were already installed, you may need to repair the installation to get them working correctly.
Maha Nadarasa
x 51
x 48
@Diaval
Diaval
x 50
x 110
You should check to make sure that you installed the options required for the shell integration.
For SW 2019
for SW 2020 or later
You can modify the SolidWorks installation from Programs and features in the control panel or Apps in settings and verify that these features were installed. If they already show as installed then I would suggest to try repairing your installation.
Maha Nadarasa
x 51
x 48
@ Diaval
My version is a standard one. I have already installed I do not know whether above option is available in standard version.
Diaval
x 50
x 110
I believe those options are available with Standard version as well. You can run the option to modify the installation without changing anything if you just want to see what has been installed.
Maha Nadarasa
x 51
x 48
I saw above type of window during the installation process. Is it possible to get it back after installation?
Diaval
x 50
x 110
You can get back to that dialog by doing a modification of the installation. If you open the Control Panel on your computer. Go to Programs and Features. Find the SolidWorks installation in the programs list. When you select it you should be given an option to Modify the installation. This will start the Installation manager again and allow you to change your installation options.
Maha Nadarasa
x 51
x 48
I tried this method before but it did not work. I will try this again.
Diaval
x 50
x 110
If you have your installation media, you can also run the setup.exe from there to modify the installation.
x 1638
x 1470
Click "Open with" "Choose another App" "More App" and pick "Solidworks" which has the highest version. Even if you're not using that.
Or pick "Solidworks Launcher"
Maha Nadarasa
x 51
x 48
@ Frederick_Law
It is not coming
RMB Menu.mp4
(2.71 MiB) Downloaded 64 times
x 1638
x 1470
Frederick_Law wrote: Mon Jul 05, 2021 8:52 am Click "Open with" "Choose another App" "More App" and pick "Solidworks" which has the highest version.
mike miller
x 1070
x 1231
Unread post by mike miller »
Maha Nadarasa wrote: Mon Jul 05, 2021 9:56 am @ Frederick_Law
It is not coming
That cursor with its constantly changing kaleidoscope of colors would drive me straight up the wall. grumph
Maha Nadarasa
x 51
x 48
It is not coming
Frederick_Law wrote: Mon Jul 05, 2021 10:57 amClick "Open with" "Choose another App" "More App" and pick "Solidworks" which has the highest version.
RBM Menu1.mp4
(4.23 MiB) Downloaded 96 times
x 1759
x 2130
mike miller wrote: Mon Jul 05, 2021 11:05 am That cursor with its constantly changing kaleidoscope of colors would drive me straight up the wall. grumph
I've seen worse. Our previous office manager had one that was a horse galloping, and the end of its nose was the pointer. I'd have needed some kind of sedation if I had to watch that constant movement all day long.
