How is everyone liking Solidworks 2022 SP1?
Alin
x 265
x 391
Re: How is everyone liking Solidworks 2022 SP1?
Unread post by Alin »
Bradfordzzz wrote: Thu Mar 31, 2022 6:10 am Mirror feature in part seems to be working, but mirror parts in an assembly and mirror sketch in assembly have issues.
Once you get the SPR from the VAR, could you please share it here?
Bradfordzzz
x 335
x 207
Unread post by Bradfordzzz »
Alin wrote: Thu Mar 31, 2022 7:46 am Once you get the SPR from the VAR, could you please share it here?
Absolutely. I'm hoping it will be a hotfix ... I really hope we don't have to wait for the next service pack.
Better yet ... I hope there is an easy work around, or some silly setting that is affecting it.
Frank_Oostendorp
x 184
x 229
HDS wrote: Thu Mar 31, 2022 7:39 am I have seen Windows 10 do this in the included programs and OS. So Microsoft has the same problem. Regardless SW will have to fix it instead of waiting for MS.
I have not experienced this behaviour in:
Google Chrome, FreeCAD, LibreCad, Microsoft Office, LibreOffice, OpenOffice, all of these programs show additional info when hoovering over the menu or commands. SolidWorks as an example, only shows part of the text.
SolidWorks uses scaling of display different in many objects. Scaling of text is used in another way on other objects.
So sometimes you will see huge row height with very small text, other object shows small row height not able to show the text.
This inconsistency makes it very hard to find settings with smaller 4K monitors (about 28" in my case). Don't want to hide behind a 48". :D
Alin
x 265
x 391
Would you please describe the issues you encountered?
Bradfordzzz
x 335
x 207
Alin wrote: Thu Mar 31, 2022 9:40 am Would you please describe the issues you encountered?
See screenshots i posted about 20 posts ago
http://cadforum.net/viewtopic.php?p=18924#p18924
mirroring looks good in the preview, but result does not work
I did a side by side comparison with Solidworks 2021 SP5.1 on one screen and Solidworks 2022 SP1 on the other screen
both had the same assembly open .. and i went thru the same steps we use everyday.
at each step i checked the settings on both screens to ensure they were the same
Solidworks 2021 SP5.1 works
Solidworks 2022 SP1 does not
x 1758
x 2129
Bradfordzzz wrote: Tue Mar 29, 2022 10:38 am Mirroring issue with Solidworks 2022 SP1
Here is the preview (settings are identical to the settings used in Solidworks 2021 Sp5.1
Here is the result
This has occurred on 4 different computers.
all using the same settings, and all settings have been verified to the settings of Solidworks 2021 Sp5.1
Any ideas?
Have you run into this issue on other Assemblies, or just this one?
Bradfordzzz
x 335
x 207
Glenn Schroeder wrote: Thu Mar 31, 2022 11:32 am Have you run into this issue on other Assemblies, or just this one?
Multiple Jobs on multiple computers all with various hardware.
I just had another Meeting with our VAR and he confirms the issue.
We recorded with Solidworks RX for further analysis.
Bradfordzzz
x 335
x 207
SPR # 1-24315938416
x 2224
x 1874
You guys have convinced me to upgrade to 2022 as time permits. I'm not terribly concerned about the minor bug here or there. (If I hit on one that affects something I do daily that might change.) What I am trying to avoid at all costs is what happened with 2019. My productivity dropped to about 25% of what it was in 2018. I can't go through that again. ("Solidworks is Busy") I still haven't turned autosave back on.
Bradfordzzz
x 335
x 207
SPerman wrote: Thu Mar 31, 2022 3:02 pm You guys have convinced me to upgrade to 2022 as time permits. I'm not terribly concerned about the minor bug here or there. (If I hit on one that affects something I do daily that might change.) What I am trying to avoid at all costs is what happened with 2019. My productivity dropped to about 25% of what it was in 2018. I can't go through that again. ("Solidworks is Busy") I still haven't turned autosave back on.
As much as I don't like 2021 ... I wish I would never have moved over to 2022.
I DO NOT RECOMMEND WHATSOEVER !!
grumph
Tera
x 483
x 91
Unread post by Tera »
It seems that it's my lucky day.
How many times I try, I don't see the problem explained in mirror. Tested on different parts/assemblies.
Maybe my assemblies are not complicated enough. (only 152 components and all sheet metals)
x 2361
x 2011
Bradfordzzz wrote: Fri Apr 01, 2022 3:57 am As much as I don't like 2021 ... I wish I would never have moved over to 2022.
grumph
Told ya...
Bradfordzzz
x 335
x 207
AlexLachance wrote: Fri Apr 01, 2022 7:41 amTold ya...
yup .. you certainly did.
hhhh
x 2361
x 2011
Bradfordzzz wrote: Fri Apr 01, 2022 8:15 am yup .. you certainly did.
hhhh
Have you moved to SP2? It should get better over time, no worries. You'll just have to deal with these pesky problems for a bit.
Bradfordzzz
x 335
x 207
AlexLachance wrote: Fri Apr 01, 2022 8:26 am Have you moved to SP2? It should get better over time, no worries. You'll just have to deal with these pesky problems for a bit.
I don't see that SP2 is out yet. maybe they are waiting to fix the mirroring before they release ;;
x 2361
x 2011
Bradfordzzz wrote: Fri Apr 01, 2022 8:41 am I don't see that SP2 is out yet. maybe they are waiting to fix the mirroring before they release ;;
I thought I read someone saying they were on SP2, but I haven't been notified of it's release so I'm leaning towards it not being released. My apologies.
Bradfordzzz
x 335
x 207
AlexLachance wrote: Fri Apr 01, 2022 8:46 am I thought I read someone saying they were on SP2, but I haven't been notified of it's release so I'm leaning towards it not being released. My apologies.
had me all excited for nothing. lol
x 2224
x 1874
grumph
Other than mirror in assemblies, what else is borken? The ONLY mirror feature that works consistently for me is mirror bodies. (This thread explains it. https://r1132100503382-eu1-3dswym.3dexp ... ulbWI0soPQ) I rarely use mirror in assemblies for similar reasons.
I'm resigned to the russian roulette of minor bugs that come with SP from SW. It's the game changers I fear. SP1 is the latest, but SP2 is due in April on the projected release schedule.
Bradfordzzz
x 335
x 207
SPerman wrote: Fri Apr 01, 2022 9:15 am Other than mirror in assemblies, what else is borken? The ONLY mirror feature that works consistently for me is mirror bodies. (This thread explains it. https://r1132100503382-eu1-3dswym.3dexp ... ulbWI0soPQ) I rarely use mirror in assemblies for similar reasons.
Mirroring Bodies still seems to be working fine.
Haven't really been able to test a lot of features in 2022 because the Mirroring function is a show stopper for us.
Working in automotive ... it seems like the vehicles happen to have both a right side .. and a left side to them . lol
x 2224
x 1874
Bradfordzzz wrote: Fri Apr 01, 2022 10:32 am Mirroring Bodies still seems to be working fine.
I typically create configurations in the sub assembly for left and right side. Most of the time none of the mirror options give me the positioning I am looking for. For me, it's easier to skin the cat a different way.
Bradfordzzz
x 335
x 207
SPerman wrote: Fri Apr 01, 2022 10:53 am I typically create configurations in the sub assembly for left and right side. Most of the time none of the mirror options give me the positioning I am looking for. For me, it's easier to skin the cat a different way.
I would agree ... but this is a function that worked in 2021 ... its only now in 2022 that this is broken (for us at least)
x 2361
x 2011
Bradfordzzz wrote: Fri Apr 01, 2022 10:58 am I would agree ... but this is a function that worked in 2021 ... its only now in 2022 that this is broken (for us at least)
It's probably a new feature
x 1231
This new "enhancement" would explain why mirroring is broken: http://help.solidworks.com/2022/English ... f6eb51#Pg0
Bradfordzzz
x 335
x 207
mike miller wrote: Mon Apr 04, 2022 7:56 am This new "enhancement" would explain why mirroring is broken: http://help.solidworks.com/2022/English ... f6eb51#Pg0
That's a really great catch. I didn't realize this change. I'm still hoping for a quick fix, like I have a check box somewhere turned on that is messing everything up. I really don't want to wait for a service pack for this. This is a big deal for our business.
TRKemp
x 59
Unread post by TRKemp »
Appreciate all of the good feedback so far from everyone. Hopefully someone can answer a few questions that I have.
Drawings - weld symbols.
For years, whenever you added a root gap and angular value to a symbol when the "2nd fillet" option was selected, the text justification was always centered which meant pushing the text to the right by way of several spacebar presses. This justification issue was apparently fixed in 2022.
SR# -- 1-2923981193
SPR# -- Description
143098 - Drawings - Annotations: Groove angle and root opening are not positioned inside bevel weld symbol with presence of 2nd fillet
Can someone:
A: confirm that it's fixed and the justification is correct on a new "fresh" symbol in 2022.
B: save a symbol on a drawing in a version of 2021 or before with the spacebar justification workaround, which you then open in 2022. I want to see if all of the default library drawings I've made over the years with weld symbols will need the "spaces" removed from them when I upgrade.
Secondly,
Can someone confirm that this SPR was fixed:
SR# -- 1-23626682349
SPR# -- Description
1194201 - Assemblies - External References, Virtual Components: Virtual Component external references status becomes out of context after parent assembly is renamed
You should be able to tell by seeing if this "search" box is present when you go to an assembly, RMB, and select "Rename".
In 2019 SP.5, when you wanted to rename an assembly, you had the option to check “include virtual components” and then hit “search” . It would then populate the virtual component references in the assembly and make sure they were redirected to the new name ensuring no broken references. This was missing in 2020 - hence the requested SPR.
Thanks!!
x 2361
x 2011
TRKemp wrote: Mon Apr 04, 2022 8:16 am Appreciate all of the good feedback so far from everyone. Hopefully someone can answer a few questions that I have.
SR# -- 1-2923981193
SPR# -- Description
Can someone:
Secondly,
SPR# -- Description
Thanks!!
Perhaps @Alin could be of help.
x 1758
x 2129
SR# -- 1-2923981193
SPR# -- Description
Can someone:
Secondly,
SPR# -- Description
Thanks!!
A. Here's what I got when I duplicated your weld symbol with SW2022 sp 0.0. I've never used the "2nd fillet" option, but I'm guessing this isn't what it's supposed to look like.
B. I didn't try anything new with virtual Parts, but I've had problems with Pack and Go in SW2022 that I never had before. When using Pack and Go, if components are re-named as part of the process the new Assembly references the original files instead of the re-named ones.
TRKemp
x 59
Hi Glenn,
I'm unable to see the example you pasted in or attached. Can you give it another try and I'll confirm if the appearance is correct.
That's also unfortunate news about Pack and go. We've just recently backported a .dll file from an SPR fix that was made in 2021 into our 2020 software to fix an unrelated issue with that feature. Re-assigning references is precisely what the pack and go function is for, so overall, that's pretty concerning.
Answers: 30
x 1202
x 1992
Bradfordzzz wrote: Thu Mar 31, 2022 2:06 pm SPR # 1-24315938416
I wonder if this is the actual SPR #1074320
Fixed in 2022 sp2
Description: Assembly - Mirror, Pattern: Location of mirrored component is wrong (shifted) when using Opposite hand version with 'New derived configuration' option after seed part modification. Preview is OK.
Bradfordzzz
x 335
x 207
jcapriotti wrote: Mon Apr 04, 2022 6:19 pm I wonder if this is the actual SPR #1074320
Fixed in 2022 sp2
Thanks Jason ! I will send this to my VAR. Would be nice if SP2 was actually available to fix the issue !
Bradfordzzz
x 335
x 207
TRKemp wrote: Mon Apr 04, 2022 2:14 pm Hi Glenn,
"Pretty Concerning" is a pretty big understatement. I think you meant "pretty f%@king nuts"
TRKemp
x 59
Bradfordzzz wrote: Tue Apr 05, 2022 4:00 am "Pretty Concerning" is a pretty big understatement. I think you meant "pretty f%@king nuts"
I won't argue with that.
x 1758
x 2129
I'm sorry about that. It appears I forgot to attach it. I didn't save it, but it looked exactly like the screenshot you posted.
TRKemp
x 59
Glenn Schroeder wrote: Tue Apr 05, 2022 8:37 am I'm sorry about that. It appears I forgot to attach it. I didn't save it, but it looked exactly like the screenshot you posted.
Ok, thanks Glenn. That's interesting that it's still not fixed, but not surprising at all either.
Also, I do still have the .dll utility files that our VAR provided for the Pack and Go fix we implemented from the 2021 SPR which solved our problems with the feature. If you're interested, I can provide those to you with some instructions I saved on how to implement it.
x 1758
x 2129
TRKemp wrote: Tue Apr 05, 2022 9:49 am Also, I do still have the .dll utility files that our VAR provided for the Pack and Go fix we implemented from the 2021 SPR which solved our problems with the feature. If you're interested, I can provide those to you with some instructions I saved on how to implement it.
I'm going to hold off for now, but thank you. I might reach out later.
Damo
x 162
x 202
Unread post by Damo »
grumph
I am genuinely sorry to hear this. TBH, I'm actually glad I made the move to 2022.
I have not experienced the Mirror bug mentioned here. (I've never liked or trusted mirror in assemblies.!! I only use it for things that are not mission critical. ie, visual references only. Any serious or important sheetmetal or weldment info is mirrored within the multi-body part. ;) )
And I truly have had a more stable and productive experience with my 2022 version install. Crashing almost never happens and I literally cannot recall the last time it did crash. I have moved all my projects that were in 2021 over to 2022 and uninstalled 2021. I see no reason to keep it. :D
Bradfordzzz
x 335
x 207
Damo wrote: Wed Apr 06, 2022 12:06 am I am genuinely sorry to hear this. TBH, I'm actually glad I made the move to 2022.
We are definitely not having the same experience. I really wish we were. I like some of these new features, just need a couple of fixes to these issues and we will be all set i think.
TRKemp
x 59
Would you mind confirming if you have any issues with Pack and Go, as Glenn described?
Also, not sure if you'd be willing to check out my post where I posed a few questions. Would be great to have additional feedback from multiple users on some of these issues.
Bradfordzzz
x 335
x 207
Our VAR had informed us that the Mirroring has been addressed and resolved in SP2.
Now we just need to wait for that to get released.
Hoping its sometimes soon !
IndianaDave
x 5
x 54
Unread post by IndianaDave »
Have they separated sheetmetal bend lines from sketch entities in flat patterns?
We hate the workaround of having to show sketches, pick the sketches and sketch lines over the bend lines, and then turn sketches off again.
Answers: 30
x 1202
x 1992
IndianaDave wrote: Fri Apr 08, 2022 9:51 am Have they separated sheetmetal bend lines from sketch entities in flat patterns?
The bend lines are still a sketch under the flat. In the drawing you show them via the view properties now.
Andy_Sanders
Unread post by Andy_Sanders »
SP2 is live.
All we are is dust in the wind, dude
-Ted
Bradfordzzz
x 335
x 207
Andy_Sanders wrote: Mon Apr 11, 2022 3:20 pm SP2 is live.
Thanks for the heads up Andy!!
I just ran the installation Manger, and it hasn't made it to me yet .. but I will check first thing tomorrow morning.
Its not in the customer portal either.
UU
x 1758
x 2129
Bradfordzzz wrote: Mon Apr 11, 2022 3:48 pm Thanks for the heads up Andy!!
UU
It shows for me. It probably will for you now also.
x 1758
x 2129
Thanks for the heads-up. I'm installing it now. I'm anxious to find out how they fixed the temporary axis fiasco.
Bradfordzzz
x 335
x 207
Glenn Schroeder wrote: Tue Apr 12, 2022 8:39 am It shows for me. It probably will for you now also.
Still not showing up for me .. WTF!
I ran Installation manager, and also checked the downloads in my portal. Still nothing.
Does it take a while to roll out to everyone?
x 2224
x 1874
Still not there for me either.
Answers: 30
x 1202
x 1992
Odd...I didn't know they did controlled rollouts to groups of users, I updated yesterday.
x 1758
x 2129
Glenn Schroeder wrote: Tue Apr 12, 2022 8:41 am Thanks for the heads-up. I'm installing it now. I'm anxious to find out how they fixed the temporary axis fiasco.
It appears that they built a delay into it. That's not what I wanted, but like my wife tells me, it's not all about me. It's a definite improvement.
Bradfordzzz
x 335
x 207
Our VAR confirmed that they don't have access to SP2 either.
Just keep waiting .. just keep waiting .. just keep waiting ... waiting ... waiting
