Page 2 of 2
Re: 1st Angle versus 3rd Angle projection
Posted: Thu May 27, 2021 10:00 am
by SamSpade
MJuric wrote: ↑Wed May 26, 2021 2:01 pm
...or 15M instead of 15000mm. Isn't this a bit like saying "I don't like imperial because there are two many digits to list 63360 inches in a mile"? The earth is 84145445920 1/64th's of an inch in circumference
You would think that when it comes to 5 or 6 digits before the decimal they would switch over from mm to M, but that's not the case, (15000mm is represented as 15000mm and not 15M). I guess it is to keep uniformity (one UOM) throughout.
Posted: Thu May 27, 2021 12:30 pm
by MJuric
SamSpade wrote: ↑Thu May 27, 2021 10:00 am
I would think one would change it as well, but not changing it to meters is not really the metric systems fault. To my knowledge there are no ISO standards that say "You have to show everything in mm".
Even if I were doing something like this in inches at some point you convert it to feet unless it's a couple really big dimension on an over all system that is much smaller. You're not going to design something that is a mi square in inches.
Posted: Fri May 28, 2021 8:56 am
by HerrTick
...but that's not the case, (15000mm is represented as 15000mm and not 15M).
Waiting for the day I see
"15kmm"...
Posted: Sat May 29, 2021 8:57 am
by zxys001
HerrTick wrote: ↑Fri May 28, 2021 8:56 am
"15kmm"...
I read that as "15 Kittens per MM"... (too early,.. adding one more uom of coffee)
