What is this blank note/frame in my sheet format?
x 1231
It is actually an empty geometric tolerance frame. I edit the sheet format, delete them (there are often two or three on top of each other), and save the sheet format. I open the DRW file template and reload the sheet format, and it's back!
What's up? grumph
Answers: 32
x 1263
x 2055
Re: What is this blank note/frame in my sheet format?
It may be in your sheet format.....not the template. Remove it and resave the sheet format instead.
x 1231
jcapriotti wrote: Thu Mar 18, 2021 3:14 pm It may be in your sheet format.....not the template. Remove it and resave the sheet format instead.
I did. And it's still there. I deleted it, saved sheet format, opened template, switched to a different size and back again. Still there. :roll:
Answers: 32
x 1263
x 2055
mike miller wrote: Thu Mar 18, 2021 3:16 pm I did. And it's still there. I deleted it, saved sheet format, opened template, switched to a different size and back again. Still there. :roll:
Edit the sheet format and then edit the Geometric tolerance box and give it some values and a symbol. Then delete it and save out the sheet format again. Not sure if I got the steps right but I did something along those lines and it went away for good.
x 1231
jcapriotti wrote: Thu Mar 18, 2021 4:09 pm
Okay, I did that but it was still on the sheet format when I opened it later. So.....I created a new .SLDDRW file using the default template, edited the sheet format, removed the frame, saved the format, then saved that current drawing as a .DRWDOT and overwrote the old template. I think that cured it!
