implemented:
- add standard layers
- replace drawing sheet templates (that's all from codestack)
- replace drafting standard
- reset all notes to use the default font
- greatly speed up the changes by not showing them
- add empty revision table to anchor
- add view label to all current views?
- chose if to add bom table/cut list/delete table?
- copy old title block to custom properties
- copy over old revision block
'Parts of this macro are from:
'Copyright(C) 2020 Xarial Pty Limited
'Reference: https://www.codestack.net/solidworks-api/document/drawing/replace-sheet-format/
'License: https://www.codestack.net/license/
'Deletes all layers and adds defined standard ones
'switches out the overall drafting standard
'sets all notes to use the default font from the drafting standard
'replaces sheet format
Const REMOVE_MODIFIED_NOTES As Boolean = True
Const FILTER_ANY As String = "*"
Dim REPLACE_MAP As Variant
Dim stdLayerMap As Variant
Dim sPath As String
'enter your desired sheet format here
'please visit https://www.codestack.net/solidworks-api/document/drawing/replace-sheet-format/ for more details
REPLACE_MAP = Array("*|*|C:\Solidworks\your sheet format.slddrt")
' this layer contains the information for all the standard layers:
' the following parameters are set:
' [Name],[DescIn],[ColorIn],[StyleIn],[WidthIn]
' Layer name, Description (can be empty), Color, Style as in swLineStyles_e, Width as in swLineWeights_e
stdLayerMap = Array( _
Array("ANNOTATIONS", "", 0, 0, 0), _
Array("BEND NOTES", "", 0, 0, 0), _
Array("BORDERS", "", 0, 0, 0), _
Array("CENTERLINES", "", 0, 4, 0), _
Array("DIMENSIONS", "", 0, 0, 0), _
Array("TABLES", "", 0, 0, 0), _
Array("VIEWS", "", 0, 0, 0), _
Array("SKETCHES", "", 0, 0, 0), _
Array("CENTER MARKS", "", 0, 0, 0))
' set the path to drafting standards here
sPath = "C:\Solidworks\your-drafting-standard.sldstd"
Set swModel = swApp.ActiveDoc
'Start performance enhancers
StartNoScreenUpdate swModel
StartLockFMT swModel
Dim swDraw As SldWorks.DrawingDoc
Set swDraw = swApp.ActiveDoc
Dim vSheetNames As Variant
vSheetNames = swDraw.GetSheetNames
Dim i As Integer
Dim activeSheet As String
activeSheet = swDraw.GetCurrentSheet().GetName
' this deletes all layers and adds the standard ones
DeleteAndAddLayers stdLayerMap, swDraw
' this replaces the overall drawing drafting standard
ReplaceDraftingStandard swDraw, sPath
' traverse through all sheets
For i = 0 To UBound(vSheetNames)
Dim sheetName As String
sheetName = CStr(vSheetNames(i))
Dim swSheet As SldWorks.sheet
Set swSheet = swDraw.sheet(sheetName)
' set all notes on this drawing sheet to the default font
SetAnnotationsToDefaultFont swDraw
Dim targetSheetFormatFileName As String
targetSheetFormatFileName = GetReplaceSheetFormat(swSheet)
' Debug.Print targetSheetFormatFileName
swDraw.ActivateSheet sheetName
' this replaces the sheet format
ReplaceSheetFormat swDraw, swSheet, targetSheetFormatFileName
' this reloads the sheet format in case it did not work our properly and gives a message
ReloadSheetFormat swSheet
Next
swDraw.ActivateSheet activeSheet
' End performance enhancers
EndNoScreenUpdate swModel
EndLockFMT swModel
' force rebuild everything
' tb implemented
Function GetReplaceSheetFormat(sheet As SldWorks.sheet) As String
Dim curTemplateName As String
curTemplateName = sheet.GetTemplateName()
Dim curSize As Integer
curSize = sheet.GetSize(-1, -1)
Dim i As Integer
For i = 0 To UBound(REPLACE_MAP)
Dim map As String
map = REPLACE_MAP(i)
Dim mapParams As Variant
mapParams = Split(map, "|")
Dim mapPaperSize As Integer
Dim srcTemplateName As String
If Trim(mapParams(0)) <> FILTER_ANY Then
mapPaperSize = CInt(Trim(mapParams(0)))
Else
mapPaperSize = -1
If Trim(mapParams(1)) <> FILTER_ANY Then
srcTemplateName = CStr(Trim(mapParams(1)))
Else
srcTemplateName = ""
If (mapPaperSize = -1 Or mapPaperSize = curSize) And (srcTemplateName = "" Or LCase(srcTemplateName) = LCase(curTemplateName)) Then
Dim targetTemplateName As String
targetTemplateName = CStr(Trim(mapParams(2)))
If targetTemplateName = "" Then
Err.Raise vbError, "", "Target template is not specified"
GetReplaceSheetFormat = targetTemplateName
Exit Function
Next
Err.Raise vbError, "", "Failed find the sheet format mathing current sheet"
End Function
Sub ReplaceSheetFormat(draw As SldWorks.DrawingDoc, sheet As SldWorks.sheet, targetSheetFormatFile As String)
Debug.Print "Replacing '" & sheet.GetName() & "' with '" & targetSheetFormatFile & "'"
Dim vProps As Variant
vProps = sheet.GetProperties()
Dim paperSize As Integer
Dim templateType As Integer
Dim scale1 As Double
Dim scale2 As Double
Dim firstAngle As Boolean
Dim width As Double
Dim height As Double
Dim custPrpView As String
paperSize = CInt(vProps(0))
templateType = CInt(vProps(1))
scale1 = CDbl(vProps(2))
scale2 = CDbl(vProps(3))
firstAngle = CBool(vProps(4))
width = CDbl(vProps(5))
height = CDbl(vProps(6))
custPrpView = sheet.CustomPropertyView
If False = draw.SetupSheet5(sheet.GetName(), paperSize, templateType, scale1, scale2, firstAngle, targetSheetFormatFile, width, height, custPrpView, REMOVE_MODIFIED_NOTES) Then
Err.Raise vbError, "", "Failed to set the sheet format"
Sub ReplaceDraftingStandard(draw As SldWorks.DrawingDoc, sPath As String)
Dim bRetVal As Boolean
Dim swModExt As SldWorks.ModelDocExtension
Set swModExt = draw.Extension
' Debug.Print "Replaced overall drafting standard with " & sPath
bRetVal = swModExt.LoadDraftingStandard(sPath)
Sub SetAnnotationsToDefaultFont(draw As SldWorks.DrawingDoc)
Dim sheet As SldWorks.sheet
Dim swView As SldWorks.View
Dim swNote As SldWorks.Note
Dim swAnn As SldWorks.Annotation
Dim swActiveView As SldWorks.View
Dim modView As ModelView
Dim bRet As Boolean
Dim bRet2 As Boolean
Set sheet = draw.GetCurrentSheet ' draw.getcurrentsheet
Set swActiveView = draw.ActiveDrawingView ' draw.activedrawingview
Set swView = draw.GetFirstView ' This is the drawing template - we change all annotations including these
While Not swView Is Nothing
' get all the notes from this view
Set swNote = swView.GetFirstNote
draw.ClearSelection2 (True)
' Debug.Print "File = " & swModel.GetPathName
Do While Not swNote Is Nothing
Set swAnn = swNote.GetAnnotation
' skip the title block annotations!
If Not swAnn.OwnerType = 2 Then
' sets annotation to use the default font
bRet = swAnn.SetTextFormat(0, True, Nothing)
bRet = swAnn.Select2(True, 0)
Set swNote = swNote.GetNext
Loop
' set the next view
' Returns FALSE if trying to activate the drawing sheet
bRet2 = draw.ActivateView(swView.GetName2):
If False = bRet2 Then
Debug.Assert sheet.GetName = swView.GetName2
bRet2 = draw.ActivateSheet(swView.GetName2)
Debug.Assert bRet2
Set swView = swView.GetNextView
Wend
Sub DeleteAndAddLayers(stdLayerMap As Variant, swModel As SldWorks.DrawingDoc)
Dim swLayerMgr As SldWorks.LayerMgr
Dim vLayerArr As Variant
Dim vLayer As Variant
Dim swLayer As SldWorks.Layer
Dim i As Integer
Set swLayerMgr = swModel.GetLayerManager
' get current layers
vLayerArr = swLayerMgr.GetLayerList
' delete all current layers
For Each vLayer In vLayerArr
Set swLayer = swLayerMgr.GetLayer(vLayer)
' Debug.Print " Layer = " & swLayer.Name
' Debug.Print " Color = " & swLayer.Color
' Debug.Print " Description = " & swLayer.Description
' Debug.Print " ID = " & swLayer.GetID
' Debug.Print " Style = " & swLayer.Style
' Debug.Print " Visible = " & swLayer.Visible
' Debug.Print " Width = " & swLayer.Width
' Debug.Print " Printable = " & swLayer.Printable
swLayerMgr.DeleteLayer (vLayer)
Next
'add all layers
For i = LBound(stdLayerMap) To UBound(stdLayerMap)
Dim layerName As String
Dim layerDesc As String
Dim layerColor As Long
Dim layerStyle As Long
Dim layerWidth As Long
Dim layerVal As Integer
layerName = stdLayerMap(i)(0)
layerDesc = stdLayerMap(i)(1)
layerColor = stdLayerMap(i)(2)
layerStyle = stdLayerMap(i)(3)
layerWidth = stdLayerMap(i)(4)
' Debug.Print " Name = " & stdLayerMap(i)(0)
' Debug.Print " Description = " & stdLayerMap(i)(1)
' Debug.Print " Color = " & stdLayerMap(i)(2)
' Debug.Print " Style = " & stdLayerMap(i)(3)
' Debug.Print " Width = " & stdLayerMap(i)(4)
layerVal = swLayerMgr.AddLayer(layerName, layerDesc, layerColor, layerStyle, layerWidth)
Next i
Sub StartNoScreenUpdate(swModel As SldWorks.ModelDoc2)
Set modView = swModel.ActiveView
modView.EnableGraphicsUpdate = False
Sub EndNoScreenUpdate(swModel As SldWorks.ModelDoc2)
modView.EnableGraphicsUpdate = True
Sub StartLockFMT(swModel As SldWorks.ModelDoc2)
swModel.FeatureManager.EnableFeatureTree = False
Sub EndLockFMT(swModel As SldWorks.ModelDoc2)
swModel.FeatureManager.EnableFeatureTree = True
Sub ReloadSheetFormat(sheet As SldWorks.sheet)
Dim reloadResult As swReloadTemplateResult_e
reloadResult = sheet.ReloadTemplate(False)
Debug.Print "Reload sheet format for <" & sheet.GetName & ">: " & GetReloadResult(reloadResult)
Private Function GetReloadResult(ByVal result As swReloadTemplateResult_e) As String
Select Case result
Case swReloadTemplate_Success
GetReloadResult = "Success"
Case swReloadTemplate_UnknownError
GetReloadResult = "FAIL - Unknown Error"
Case swReloadTemplate_FileNotFound
GetReloadResult = "FAIL - File Not Found"
Case swReloadTemplate_CustomSheet
GetReloadResult = "FAIL - Custom Sheet"
Case swReloadTemplate_ViewOnly
GetReloadResult = "FAIL - View Only"
Case Else
GetReloadResult = "FAIL - <unrecognized error code - " & result & ">"
End Select
End Function
