Flat Pattern orientation
Posted: Wed Oct 13, 2021 4:19 am
by SolidKeke
Hi guys,
Is there an easy way to rotate Flat pattern view in a drawing so that bounding box edges are horizontal/vertical. See the attached image. My problem is that some parts just doesn't have any parallel edge with bounding box so I have to manually rotate the view, or as usual just leave it crooked since I'm too lazy...
This is how the view looks after insertion
This is final version after measuring the angle and rotating it manually. Too much work for my lazy a**.
Re: Flat Pattern orientation
Posted: Wed Oct 13, 2021 5:19 am
by Lapuo
Can you use relative view?
Posted: Wed Oct 13, 2021 6:00 am
by SolidKeke
Lapuo wrote: ↑Wed Oct 13, 2021 5:19 am
Hi, thank you for a reply.
How ever, your suggestion doesn't work for this problem I guess, or then I just don't know how to do it properly.. Can you be more specific or maybe show an example?
Posted: Wed Oct 13, 2021 7:53 am
by DanPihlaja
SolidKeke wrote: ↑Wed Oct 13, 2021 6:00 am
See the attached GIF file (or click on the picture below to view it).
Posted: Wed Oct 13, 2021 8:31 am
by Dwight
Nice demo. I haven't had the need to apply the technique, but I am sure I will in the future.
Posted: Wed Oct 13, 2021 9:53 am
by Ömür Tokman
SolidKeke wrote: ↑Wed Oct 13, 2021 4:19 am
dpihlaja wrote: ↑Wed Oct 13, 2021 7:53 am
I couldn't decide which one was easy.
Posted: Wed Oct 13, 2021 2:16 pm
by zxys001
Or,.. Save a View Name (my lazy a**) relative to normal you want in the sldprt and use that Saved View Name in your slddrw.
Posted: Thu Oct 14, 2021 1:08 am
by SolidKeke
This is definitely an awesome trick, but when I use the relative view I see only the bent model, no flat pattern. In your example you don't use sheet metal but a regular boss-extrude.
Posted: Thu Oct 14, 2021 7:59 am
by DanPihlaja
SolidKeke wrote: ↑Thu Oct 14, 2021 1:08 am
Yes, I was just going for how to create the relative view.
Once you have the orientation down, and you have placed the view, you can then select the drop down in the view.
- image.png (9.18 KiB) Viewed 1310 times
As, one other user said, another way is to save a view in the 3d model and then use that view in your drawing.
