any one out there have any info on AIA cad layer guidelines as set forth in the national cad standard .org?
nationalcadstandard.org
cad layer standards
- x 55
- x 70
- x 2489
- x 1899
Re: cad layer standards
You're in luck. The Army Corps adopted it. So, it's available through them.
Here's a link: https://usace.contentdm.oclc.org/digita ... l1/id/3835
Also, we copied and altered it a little for our needs. I have attached a copy.
- v1.4-2D CAD Standards.pdf
- (2.22 MiB) Downloaded 393 times
Even though ANSI or ASTM starndards are not that useful here in the Scandinavia, I still appreciate information. Thanks, Matt!
Sincerely,
JuTu
__________________
Lentäjä on ulkona ja lukossa.
JuTu
__________________
- x 2489
- x 1899
Compare what we've done to the original and if it makes sense, by all means use what we've done. IIRC, we modified some of the layer naming and specified things like it has to be third angle projection, that will always be the same for us. Because you are in Scandinavia, it'll definitely require modifying for metric, etc.
