can't select other
Posted: Mon Nov 15, 2021 12:13 pm
by KSHansen
I'm trying to add some screws to my assembly. I need to right-click and Select Other to choose the holes for my mates. But when I right-click, nothing happens. Any idea why that is? I have to spin the model and zoom in so I can see the edge of the hole and select it that way.
This happens a lot when I'm trying to Copy With Mates, and not as much when I'm just trying to do new mates. At first I thought there was some trick I didn't know, but now I see it's rather erratic, so I'm going to guess it's not intended functionality. What do you think?
Re: can't select other
Posted: Mon Nov 15, 2021 12:19 pm
by KevinC
Can you post some screen shots of your issue.
Also, look into Pattern Driven Component Pattern.
Posted: Mon Nov 15, 2021 12:49 pm
by KSHansen
I can't upload anything to this site. Files or screenshots.
But the screenshot would show a pointer-cursor with a little icon of a mouse, with the right button in blue. And when I click the RMB, nothing happens.
Posted: Mon Nov 15, 2021 1:34 pm
KSHansen wrote: Mon Nov 15, 2021 12:49 pm I can't upload anything to this site. Files or screenshots.
Click on the "Full Editor & Preview" button. Then you'll be able to attach files and screenshots.
Posted: Mon Nov 15, 2021 3:04 pm
I've seen the same thing. Sometimes the "select other" option is available, and sometimes it isn't. (2020 SP5)
Posted: Mon Nov 15, 2021 4:56 pm
by zxys001
KSHansen wrote: Mon Nov 15, 2021 12:13 pm I'm trying to add some screws to my assembly. I need to right-click and Select Other to choose the holes for my mates. But when I right-click, nothing happens. Any idea why that is? I have to spin the model and zoom in so I can see the edge of the hole and select it that way.
Yep, this happens. I do NOT know a solution to the problem. And, it's also like this in part mode. :roll:
Posted: Mon Nov 15, 2021 5:01 pm
It's because the "Copy with mates" command has a right click to go to the next step option programmed in. Press the "alt" key with your mouse cursor over the faces you want to hide. You should be able to get down to the hole face.
Posted: Mon Nov 15, 2021 5:04 pm
by KSHansen
Glenn Schroeder wrote: Mon Nov 15, 2021 1:34 pm Click on the "Full Editor & Preview" button. Then you'll be able to attach files and screenshots.
Thanks for the tip, but it still doesn't work. I can't upload files of any type. I can't even change my user avatar. I get a message that shows:
ERROR
HTTP Error
Posted: Mon Nov 15, 2021 5:20 pm
by KSHansen
Actually, when I try to upload an avatar, it tells me "Sorry, you don't have permission to visit this site." That's my company's internet policy. The other situations I get the HTTP error.
Posted: Mon Nov 15, 2021 6:29 pm
You don't work for Dassault do you? @mattpeneguy might've got us blacklisted.
On a serious note, looks like you'll need to get you IT to allow access.
Posted: Tue Nov 16, 2021 11:46 am
by KSHansen
No, I don't. I wonder if I could get help with my issue if I did...
I don't think I would bother them, just so I could upload an avatar. Though I'm not sure if the http error thing is related to that, or a separate issue.
Posted: Tue Nov 16, 2021 1:48 pm
KSHansen wrote: Tue Nov 16, 2021 11:46 am No, I don't. I wonder if I could get help with my issue if I did...
Someone else here got the HTTP error, maybe @matt is aware.
Posted: Tue Nov 16, 2021 2:27 pm
by matt
jcapriotti wrote: Tue Nov 16, 2021 1:48 pm Someone else here got the HTTP error, maybe @matt is aware.
If it's on your end, there's nothing I can do. I wish browsers had a plain english "debug" button that would show you which server along the chain is sending the message. No settings here have changed in weeks. You should be able to upload attachments with the full editor, and even paste clipboard images directly into the text window.
Posted: Tue Nov 16, 2021 2:28 pm
by mike miller
works here
Posted: Tue Nov 16, 2021 3:28 pm
mike miller wrote: Tue Nov 16, 2021 2:28 pm CRASH!!.jpg
works here
Does that mean "select other" cad tool?
Posted: Wed Nov 17, 2021 7:29 am
by mike miller
jcapriotti wrote: Tue Nov 16, 2021 3:28 pm Does that mean "select other" cad tool?
Pictures work. No voucher is made for either the select other tool or SWX......
Posted: Sat Nov 20, 2021 11:37 am
by KSHansen
test
Now i'm on my home computer, pasting an image from my clipboard.
Edit: it works. I'll think about asking IT to whitelist me for this "social media" site.
Posted: Sun Nov 21, 2021 10:28 am
by gupta9665
Try RMB while cursor is on some face/edge/vertex
Posted: Sun Nov 21, 2021 9:39 pm
by zxys001
...ya know,..everyone will try to show some workaround here..but the reality is..the cursor proximity should provide a reasonable selection set...and it does NOT. SW Corp needs to fix it!...sorry but it's been effn years and nothing has friggin changed😡
