meaning of the term "peer"
Posted: Fri Nov 19, 2021 11:19 am
by matt
There are some things in SE that I'm a little slow on the uptake. The use of the word "peer" is one of those. I kind of vaguely get that a "peer" is a part in an assembly related somehow to the part currently being considered.
There are several concepts or commands with the word "peer" in the name. Can anyone kind of outline how the word is used and the various contexts in which it is used?
- peer edge locate
- peer silhouette locate
- peer variables
Re: meaning of the term "peer"
Posted: Fri Nov 19, 2021 11:38 am
by KennyG
matt wrote: Fri Nov 19, 2021 11:19 am There are several concepts or commands with the word "peer" in the name. Can anyone kind of outline how the word is used and the various contexts in which it is used?
- peer edge locate
- peer variables
Peer is typically used in the context of assembly to refer to components that are at the same level. You could actually replace "Peer" with "Component" and it still mean the same thing.
Peer Edge Locate - Allows locating the edges of other components typically while sketching. Turn it off and you can't locate them for instance while drawing a line.
Peer Silhouette Locate - Same as above, but filters the virtual "horizon" edge of say the side of a cylinder.
Peer Variable - Allows accessing the variable table of selected component.
Posted: Fri Nov 19, 2021 11:51 am
by matt
KennyG wrote: Fri Nov 19, 2021 11:38 am Peer is typically used in the context of assembly to refer to components that are at the same level. You could actually replace "Peer" with "Component" and it still mean the same thing.
Thanks, that's kind of what I thought, but I wanted to make sure. Are there other settings or commands or options where it uses the peer concept? Those were the only ones I found using the Command Finder.
Posted: Fri Nov 19, 2021 12:09 pm
by KennyG
matt wrote: Fri Nov 19, 2021 11:51 am Thanks, that's kind of what I thought, but I wanted to make sure. Are there other settings or commands or options where it uses the peer concept? Those were the only ones I found using the Command Finder.
I think that is about it other than here is a Component Edge Locate in the Part env that turns locate ON/OFF for it's own geometry while sketching.
Posted: Sat Nov 20, 2021 8:07 am
by gupta9665
I thought you accidently wrote Peer instead of Beer UU
Posted: Sat Nov 20, 2021 10:18 am
by matt
gupta9665 wrote: Sat Nov 20, 2021 8:07 am I thought you accidently wrote Peer instead of Beer UU
Yeah, I need more beer talking about peers.
Posted: Sat Nov 20, 2021 4:26 pm
matt wrote: Sat Nov 20, 2021 10:18 am Yeah, I need more beer talking about peers.
This settles it, we have PDM state called "Engineering Peer Review". I think I'll change it to "Beer" and see who notices.
