Help with automating a Macro.
Posted: Tue Nov 23, 2021 4:48 am
by panzerscope
Hello all, new here!
Hoping to get some assistance. As per the code exerpt below, I cobbled together a Macro that when initiated will force the user to save their drawing and will then proceed to export a PDF and DWG, or DXF. (Comes up with a selection menu).
However rather than having the user click on a Macro button in Solidworks, I wanted to automate this further so that every time as user clicks the default save button in Solidworks, this Macro is initiated.
Granted, when clicking the save button in Solidworks would already take care of the user saving his work before the Exports happen, so you could likely lose the
swModel.Extension.RunCommand swCommands_SaveAs, Empty
from the below.
I found a resource here which looked to solve my problem :
However I cannot seem to get it to work, I am evidently misunderstanding how to implement this correctly, I am a novice at Macro and VB.
Could anyone help me with this ? For ease I also attached the current Macro file.
Thanks in advance.
P
'Export Open Drawings as PDF_DWG (SW2019).swp ------------- 01/30/19
'Description: Macro to export all open drawings as PDF and DWG.
'Pre-Condition: An open drawing which has been saved and has one model view. The model should have the
' PartNumber, Revision and Description custom properties with values added.
'Post-Condition: Macro save active drawing as PDF and DXF in same location as the drawing file with
' PartNumber, Revision and Description custom properties values from referenced model as the file name.
' The macro would process all open drawings and would export only those drawings which has been saved and contains minimum one model view.
' Please back up your data before use and USE AT OWN RISK
' Created by Deepak Gupta (Boxer's SOLIDWORKS Blog, India) http://gupta9665.com/
' Disclaimer:
' This macro is provided as is. No claims, support, refund, safety net, or
' warranties are expressed or implied. By using this macro and/or its code in
' any way whatsoever, the user and any entities which the user represents,
' agree to hold the authors free of any and all liability.
' Free distribution and use of this code in other free works is welcome.
' You may redistribute it and/or modify it on the condition that this header is retained.
' All other forms of distribution (i.e., not free, fee for delivery, etc) are prohibited
' without the expressed written consent by the authors.
' Use at your own risk!
Option Explicit
Dim swDrawModel As SldWorks.ModelDoc2
Dim swView As SldWorks.View
Dim nErrors As Long
Dim nWarnings As Long
Dim Revision As String
Dim Description As String
Dim PartNumber As String
Dim nFileName As String
Dim sFileName As String
Dim nResponse As Integer
Dim FileSave As Boolean
Dim sDrawingCol As New Collection
Sub Main()
Set swDrawModel = swApp.GetFirstDocument
Set swModel = swApp.ActiveDoc
' Check to see if a drawing is loaded.
If swDrawModel Is Nothing Then
MsgBox "There is no active drawing document"
Exit Sub
End If
Do While Not swDrawModel Is Nothing
If swDrawModel.GetType = swDocDRAWING Then
sDrawingCol.Add swDrawModel.GetPathName
Debug.Print swDrawModel.GetPathName
End If
Set swDrawModel = swDrawModel.GetNext
Loop
If sDrawingCol.Count > 0 Then
'Set file export type
nResponse = MsgBox("Select YES (PDF & DWG) OR NO (DXF) OR CANCEL (Exit/End)?", vbYesNoCancel)
If nResponse = vbYes Then
FileSave = True
ElseIf nResponse = vbNo Then
FileSave = False
ElseIf nResponse = vbCancel Then
Exit Sub
End If
Else
Exit Sub
End If
Set swDraw = swDrawModel
If swDraw.GetPathName <> "" Then
sFileName = Mid(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\") + 1)
swApp.ActivateDoc3 sFileName, False, swDontRebuildActiveDoc, nErrors
Else
MsgBox "This drawing: " & UCase(swDraw.GetTitle) & " has not been saved, " & vbCrLf & _
"jumping to next drawing (if available) else ending the macro"
GoTo Jump
End If
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
If Not swView Is Nothing Then
Set swModel = swView.ReferencedDocument
Else
MsgBox "No model view found in this drawing: " & UCase(swDraw.GetTitle) & ", " & vbCrLf & _
GoTo Jump
End If
'Get Model Properties
PartNumber = swModel.GetCustomInfoValue("", "Part Number")
Revision = swModel.GetCustomInfoValue("", "Revision")
Description = swModel.GetCustomInfoValue("", "Description")
If Revision = "" Then
Revision = ""
End If
'nFileName = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\")) & PartNumber & "-" & Revision & " " & Description
' Comment out above line and remove comment from following line in case you want to simply save the draing file with its own name.
nFileName = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\")) & sFileName
If FileSave = True Then
'Save as DWG (replace DWG with DXF in following line in case you want to save as DXF)
'Note that DWG will export to one or multiple sheets depending on your solidworks DWG export settings
swDraw.SaveAs3 nFileName & ".DWG", 0, 0
'Save as PDF`
swDraw.SaveAs3 nFileName & ".PDF", 0, 0
ElseIf FileSave = False Then
swDraw.SaveAs3 nFileName & ".DXF", 0, 0
End If
End If
Jump:
Loop
Set sDrawingCol = Nothing
Re: Help with automating a Macro.
Posted: Tue Nov 23, 2021 9:13 am
by AlexB
It's possible to do this several ways with varying levels of involvement with the programming. The following article goes into detail on how to set this up.
Handling Solidworks Events - Codestack.net
Posted: Tue Nov 23, 2021 10:22 am
by gupta9665
The macro here by @artem https://www.codestack.net/solidworks-ap ... ment-save/ should be helpful.
