SW note convert Autocad note
Ömür Tokman
x 993
x 345
Unread post by Ömür Tokman »
Hi Guys,
The notes you write in sw always turn into the same font in autocad.
Is there any way to prevent this?
by Shaun » Fri Nov 26, 2021 11:41 am
Hi, I don't seem to get this problem.
See below in SW
And Autocad/TruView
These are the settings I use to export under system options. I am using SW2019.
Don't know if this helps you at all.
Shaun
x 30
x 6
Re: SW note convert Autocad note
Unread post by Shaun »
See below in SW
And Autocad/TruView
Ömür Tokman
x 993
x 345
Shaun wrote: Fri Nov 26, 2021 11:41 am Hi, I don't seem to get this problem.
Thanks a lot Shaun
I'm marking your answer as correct since you answered before me.
Thank you again.
Actually I found the answer here (Rob E. showed)
https://help.solidworks.com/2017/Englis ... ON_DXF.htm
