SOLIDWORKS TTL (continued)
Vote for your top SWX enhancements
Bring back online licensing
10
14%
Bring back the HUL (Home User License)
11
15%
Allow either multiple BOM sorting filters, or to select a Sort from favorites
3
4%
Better control over depth and direction of broken-out section views
4
6%
Toggle display of transparent parts in drawing views
5
7%
Fix the sheet metal gauge table to eliminate random errors
5
7%
Allow derived parts to reference the parent gauge table
4
6%
Autoballoon should not add balloons to parts that are excluded from the BOM
6
8%
Purge unused data in drawings, to help rein in Drawing file size "creep"
3
4%
Batch Printing to auto print selected drawings based on paper size
1
1%
Add or redo the corner treatment tool in Sheet Metal (allow interior corners, more selection automation)
4
6%
Add an option to not consume features in the tree (Flat Tree Display doesn't work for sheet metal)
3
4%
Highlight referenced edges or points when you click on a dimension in a drawing.
4
6%
Allow reattaching dimensions in a "ALL" cases even changing the type of geometry it was originally attached to.
4
6%
Improve performance of editing/selecting dimensions and annotations in the model and drawing environments.
2
3%
Copy the "View Cube" concept and replace the Triad.
2
3%
Allow holding right mouse button down to pan whereas a single click and release displays the context menu.
0
No votes
OPT 18
0
No votes
OPT 19
0
No votes
OPT 20
0
No votes
Total votes: 71
x 1231
This is an extension of the original post due to the limitation of <20 poll options per thread.
All options marked as "OPT 15", for example, are merely placeholders for new ideas.
x 2489
x 1899
Re: SOLIDWORKS TTL (continued)
The 1980's called and said they were happy with the SW drawing view rotation functionality...
Uncle_Hairball
x 37
x 95
Better control over depth and direction of broken-out section views.
Uncle_Hairball
x 37
x 95
When creating drawing views containing transparent parts, it would be helpful to have a switch to display the transparent parts as transparent. Not so useful in detail drawings; mostly for assemblies.
Uncle_Hairball
x 37
x 95
Autoballoon should not add balloons to parts that are excluded from the BOM. If it's not in the BOM, what is the balloon going to tell you? An asterisk is meaningless.
m2shell
x 121
x 57
Unread post by m2shell »
Bradfordzzz
x 347
x 210
Unread post by Bradfordzzz »
https://r1132100503382-eu1-3dswym.3dexp ... j9ttEoTlfw
Batch Printing to auto print selected drawings based on paper size to multiple Printers that have configurable predefined settings.
for example.
A size to printer #1 tray # 1 (with configurable predefined settings)
B size to printer # 1 tray # 2 (with configurable predefined settings)
D size to plotter # 1 (with configurable predefined settings)
E size to plotter # 1 (with configurable predefined settings)
custom size to plotter # 2 (with configurable predefined settings)
x 2577
x 1427
Add or redo the corner treatment tool in Sheet Metal toolbar. It should perform radius or angle on an internal (fillet) or external corner. The selection mode should only allow selecting corners on the edge of the material. Maybe clicking a face will select all the edge corners connected to that face? There's could be some handy selection behavior improvements incorporated.
This tool should work in any config, unlike the existing SM Break corner feature that mostly only works in the flattened model.
x 2577
x 1427
Add option to leave sketche(s) out of the feature that uses it/them. I plan my first several sketches out carefully and SW clobbers the intent order and buries them in features down the tree. This makes edits cumbersome as I often roll back to the sketch to edit it, but everything is out of order.
NOT the Tree Display -> Show Flat Tree View; it is not consistent, especially flaky in Sheet Metal.
tsmith
x 99
x 30
Unread post by tsmith »
bnemec wrote: Thu Dec 09, 2021 10:27 am Add option to leave sketche(s) out of the feature that uses it/them. I plan my first several sketches out carefully and SW clobbers the intent order and buries them in features down the tree. This makes edits cumbersome as I often roll back to the sketch to edit it, but everything is out of order.
Agreed on how that obfuscates the process in a dramatic and confusing way. I typically create several 'control' sketches on the cardinal planes and then create sacrificial sketches (rapidly, with the convert entities tool) that get consumed into the features. This enables myself and other users to rapidly find and adjust key dims.
Combine this with the resilient modeling system's sequence of events and you can actually make some bullet proof models.
x 2577
x 1427
tsmith wrote: Thu Dec 09, 2021 8:37 pm Agreed on how that obfuscates the process in a dramatic and confusing way. I typically create several 'control' sketches on the cardinal planes and then create sacrificial sketches (rapidly, with the convert entities tool) that get consumed into the features. This enables myself and other users to rapidly find and adjust key dims.
What you explain is my favorite method for majority of parts, especially sheet metal parts. I just am not used to needing the sacrificial sketches (nice term by the way) and I am leery of relying on Convert Entities as a critical link in the process. Sometimes the extra layer does help save geometry/face IDs as the derived sketches/curves can be redefined instead of deleted and made new.
It sounds like you have found that the Convert Entities to be very solid and robust in keeping with changes in the control sketches? I will step in faith and try the sacrificial sketches method.
Jaylin Hochstetler
x 380
x 355
SE has this capability:
Edit to add:
https://r1132100503382-eu1-3dswym.3dexp ... yva-gkzwGQ
Answers: 32
x 1260
x 2047
Allow reattaching dimensions in a "ALL" cases even changing the type of geometry it was originally attached to (edge to vertex or sketch entity, etc).
Answers: 32
x 1260
x 2047
Improve performance of editing/selecting dimensions and annotations in the model and drawing environments. This should be lightning quick but there are delays waiting on the property manager or popup edit box to appear.
Answers: 32
x 1260
x 2047
Allow holding right mouse button down to pan whereas a single click and release displays the context menu. (See Onshape for details).
Bonus: Allow mapping these actions instead of hardcoding it.
Answers: 32
x 1260
x 2047
There is no shaming in copying. Not sure who came up with it first, but Inventor, Onshape, and Solid Edge all have it and it works great.
x 2323
x 1950
jcapriotti wrote: Mon Dec 13, 2021 11:24 am Allow holding right mouse button down to pan whereas a single click and release displays the context menu. (See Onshape for details).
I would really like a way to pan that uses a momentary switch, not a latching one.
x 1231
Wouldn't that interfere with mouse gestures?
jcapriotti wrote: Mon Dec 13, 2021 11:35 am Copy the "View Cube" concept and replace the Triad.
Tell me about it. <ll> SE view orientation and 3D mouse control is a generation ahead of SWX. At least.
SE view cube.mp4
(7.29 MiB) Downloaded 251 times
Answers: 32
x 1260
x 2047
mike miller wrote: Mon Dec 13, 2021 12:00 pm Wouldn't that interfere with mouse gestures?
I turn that off so no. I have the "S" key, why would need mouse gestures too.
mike miller wrote: Mon Dec 13, 2021 12:00 pm Tell me about it. <ll> SE view orientation and 3D mouse control is a generation ahead of SWX. At least.
Not sure who came up with the cube first but it works wonderfully. I find it strange that Siemens hasn't added it to NX though.
SolidWorks "tried" to one up everyone with the dynamic spacebar invoked view selector. The problem is its a bit disorienting and slow, especially in large assemblies, I have it turned off.
