I'm sure there is an answer but it's quicker to ask....
I'm doing a drawing of a TABLE (4 legs and a surface)
In the top view I would like to see the surface translucent so that I can see the legs under the table.
I know I can change "Change transparency" of the part in the model and then make the view "Shaded with Edges" to match but that shades all the other parts.
Is there a way (in the drawing) to "Change transparency" of the part while keeping the view "hidden with Edges"
Change translucency Hidden line removed
- x 1632
- x 2044
Re: Change translucency Hidden line removed
Is this table an Assembly, or a multi-body Part?
- x 1132
- x 1940
You could create a display state in the model and set the table top part to wireframe. Then show that Display State in the drawing view.
It is an assembly
I tried that but It needs to be in "Shaded with Edges".jcapriotti wrote: ↑Wed Dec 15, 2021 3:13 pm You could create a display state in the model and set the table top part to wireframe. Then show that Display State in the drawing view.
I would like "Hidden Edges Removed" as that has no shading.
- x 1132
- x 1940
Got it!
It is a combination of creating a Display State where the assembly is in "Shaded with Edges" and then the "Component Display" of the components are changed to "Wireframe" and "Hidden Lines Removed". The drawing view then uses the new Display State which is actually "Shaded with Edges".
Thank you. It makes sense now.
- x 1132
- x 1940
Actually in that second pic, I just did a standard Hidden Line Removed view. Then right click the legs and show hidden edges. No special Display State needed in that case.Bryan O wrote: ↑Thu Dec 16, 2021 8:28 am Got it!
