Quickly find Draft feature in feature tree
Posted: Thu Dec 16, 2021 9:53 am
by zwei
Is there a easy way to find a draft feature in feature tree?
Unlike normal feature which will show up in breadcrumb, for some reason draft just wont show up in breadcrumb
If the face is drafted using neutral plane, selecting the face will highlight the feature in the tree but will not automatically point you to the feature in the tree (eg: if you have a long tree, you wont really notice the highlighted feature in the tree until you scroll down)
If the face is drafted using parting line, selecting the face will not highlight any feature, if you have like 50+ draft feature, finding that particular draft can be a nightmare
Re: Quickly find Draft feature in feature tree
Posted: Thu Dec 16, 2021 12:40 pm
by DanPihlaja
...selecting the face will highlight the feature in the tree but will not automatically point you to the feature in the tree (eg: if you have a long tree, you wont really notice the highlighted feature in the tree until you scroll down)...
Do you have this checked?
Posted: Thu Dec 16, 2021 5:33 pm
by zwei
dpihlaja wrote: ↑Thu Dec 16, 2021 12:40 pm
Yes i do, the problem is when i selected the face it scroll to the base feature (eg: extrude) instead of the draft,
Posted: Fri Dec 17, 2021 7:55 am
by DanPihlaja
Zhen-Wei Tee wrote: ↑Thu Dec 16, 2021 5:33 pm
Yes, I found that out after I posted that. Woops.
The only other thing that I can think of is to use the filter in the tree.
Posted: Tue Dec 28, 2021 8:07 pm
by zwei
dpihlaja wrote: ↑Fri Dec 17, 2021 7:55 am
Most of the time our part has like 50+ draft, filtering for draft does not really help
, not to mention most of the folks dont even bother to name their feature...
So far the only viable option that i find is to look really closely at the feature tree dependencies
- image.png (10.01 KiB) Viewed 1160 times
Or use an extra click to find the child dependencies
- image.png (13.07 KiB) Viewed 1160 times
Posted: Wed Dec 29, 2021 4:40 am
by Marco
Don't you have this when you select a feature in your assembly or part? You can click on the feature or sketch and it will take you to the feature in the tree.
If you do not have this option switched on you can switch on the breadcrumbs
Posted: Wed Dec 29, 2021 4:52 am
by takedownca
What version of SW? In SW2018 when I select a drafted face, the actual draft feature is selected in the feature tree. Also, Dynamic Reference Visualization (parent/child arrows) is enabled, selecting the base feature in the tree will result in a child arrows being displayed, including any draft features.
Posted: Wed Dec 29, 2021 5:30 pm
by zwei
Marco wrote: ↑Wed Dec 29, 2021 4:40 am
Yes i have the breadcrumb option activated.
The issue is with the draft feature not showing up in the breadcrumb as shown in the image below
The example part has the OD drafted with a draft feature.
I had selected the drafted face, but the breadcrumb show the bread-extrude instead
Posted: Wed Dec 29, 2021 5:33 pm
by zwei
takedownca wrote: ↑Wed Dec 29, 2021 4:52 am
SW2019
Yes it highlight in the feature tree but for some reason it did not bring me directly to the draft feature (unlike when you select other face created with feature like cut or boss extrude), and it is not showing up in the breadcrumb.
When the feature tree has like 100+features, it is a real pain finding the draft (lots of scrolling)
Posted: Wed Dec 29, 2021 7:21 pm
Yeah, unlike other features, draft doesn't actually create any geometry......more like a direct edit on the face.
Posted: Wed Jan 05, 2022 6:51 am
by sergio.monti
Yes, this is very annoying... You can try to combine the two functions: use filter "Draft" on the top of the feature tree and then select the draft in the view and hope that the tree will still not be too long so you can see the highlighted draft!!!
