What determines the SW direction when converting to Dxf?
Ömür Tokman
x 995
x 347
Unread post by Ömür Tokman »
Hello guys,
have a good day,
most of the time it is different from the view I set.
Is there a way to save as I set it?
Frank_Oostendorp
x 230
Re: What determines the SW direction when converting to Dxf?
To avoid to have to change DXF orientation, we sketch on the front plane, in the view orientation we prefer for the DXF, having the optional special surface of the sheet metal towards you.
Ömür Tokman
x 995
x 347
Frank_Oostendorp wrote: Tue Dec 21, 2021 6:39 am To avoid to have to change DXF orientation, we sketch on the front plane, in the view orientation we prefer for the DXF, having the optional special surface of the sheet metal towards you.
I determine the flat pattern surface, there is no problem in that. (macro) .
If you pay attention to the drawing, it rotates clockwise. I want to prevent this.
edit:
Additionally, that's not the method I'm talking about. yes, it is determined in this way and results in the correct output, but it is necessary to deal with each part individually. I am getting dxf from the assembly with the help of a macro.
Answers: 32
x 1256
x 2045
Edit the "Flat-Pattern" feature. There is a "fixed" face selection you can change. This will drive the "up" side shown when exporting, yours is most likely on the back face which is flipping it over. Unfortunately, I don't believe there is a way to control the rotation except as in the export dialogue to define an X-Y direction.
Ömür Tokman
x 995
x 347
jcapriotti wrote: Tue Dec 21, 2021 12:05 pm Edit the "Flat-Pattern" feature. There is a "fixed" face selection you can change. This will drive the "up" side shown when exporting, yours is most likely on the back face which is flipping it over. Unfortunately, I don't believe there is a way to control the rotation except as in the export dialogue to define an X-Y direction.
Hi @jcapriotti Thank you for the answer, the face is in the right direction. there is no problem with that, i was just looking for a way for xy.
Answers: 26
x 445
x 469
Ömür Tokman wrote: Wed Dec 22, 2021 1:19 am Hi @jcapriotti Thank you for the answer, the face is in the right direction. there is no problem with that, i was just looking for a way for xy.
Alignment array takes care of the XYZ
Ömür Tokman
x 995
x 347
then as i understand i need to start drawing by calculating yxz in order to position flat pattern correctly.
Frank_Oostendorp
x 230
By sketching on the front plane, or importing an existing DXF and rotate this in the desired rotated angle, and extrude the sheet, we always have the desired result of side and angle in the exported DXF of the front surface of the unfolded sheet metal part. No need to do anything more.
Joe Soo
Unread post by Joe Soo »
Hi, everyone,
Is it possible by assign a new coordinate system having its X-axis aligned with the edge which to be horizontal in the DXF output?
ChatGPT generated the code below:
'Define the coordinate system name (should match the one in your parts)
coordSystemName = "CoordSys1" ' Adjust this name as needed
'Set the export options
Set swExportMgr = flatPattern.GetExportFlatPatternData
dxfOptions = swExportFlatPatternToDXF
swExportMgr.SetOutputType dxfOptions
swExportMgr.SetCoordinateSystem coordSystemName
However, I am not able to make it works.
I am not a macro guy, hope someone can help out if it is possible by Modify the "Export flat patterns from SOLIDWORKS part or assembly components".
It is useful for sheet metal SS304 which having a grain direction requirement.
