Duplicate a part with dependenties
Posted: Tue Dec 21, 2021 11:58 am
by Schtiggltiz
Hello everyone !
My problem :
I want to create a part based on an otherone, and then apply some modification on it.
Once done, I could add drills (for exmaple) without any modification on my primary part. But if I modify the primary part, the "daugther" one will also be modified.
The only solution I currently have is :
- Create a symmetrical part (insert -> symmetrical part)
- Create an other symmetrical part from the first one
That is it, I have my copy of the primary part, which will change if I apply any change on the primary one. This method is not optimised and presents some disadvantages (for example the update is time consumming).
Do you have any advice ?
Thanks in advance guys !
Hugo
Re: Duplicate a part with dependenties
Posted: Tue Dec 21, 2021 1:18 pm
by mike miller
You could try "part in part". Open a new part file, go to Insert>Part and select the master you want to reference. This opens a dialog that allows you to choose exactly what you want to bring into the new part (solids, surfaces, sketches, planes, etc.).
Posted: Wed Dec 22, 2021 3:25 am
by Schtiggltiz
Hello Mike,
That's it, it works perfectly !
Thank you for your time and advice, have a good day.
Posted: Wed Dec 22, 2021 9:51 am
by XHawkeye
mike miller wrote: Tue Dec 21, 2021 1:18 pm You could try "part in part". Open a new part file, go to Insert>Part and select the master you want to reference. This opens a dialog that allows you to choose exactly what you want to bring into the new part (solids, surfaces, sketches, planes, etc.).
Ditto try Insert Part, use it all the time.
One of our products has a pressed on cover, so insert the housing into the cover file to create the grooves for the press fit.
Also use it to create assembly fixtures.
