I need to manufacture a 42" long x 2" od 6061-T6 shaft that is centerless ground and gun drilled. This will be a low volume run, which makes it even more challenging. Can anyone point me to a resource that can handle this? I've located a handful of companies from searching the internet, but I thought this group may be able to recommend someone to me.
Looking for a specialty machine shop
- zxys001
- x 2267
- x 969
Re: Looking for a specialty machine shop
..yeah,..the first one which came up... http://precisiontube.com/capabilities/what-we-do
- x 738
- x 893
There is a guy that I use in Grand Rapids that is one of the best Machinists I know. He does all sorts of specialty stuff for me. Including the micro machining of the cathodes that I need for the ECD machine here.SPerman wrote: ↑Thu Jan 06, 2022 4:15 pm I need to manufacture a 42" long x 2" od 6061-T6 shaft that is centerless ground and gun drilled. This will be a low volume run, which makes it even more challenging. Can anyone point me to a resource that can handle this? I've located a handful of companies from searching the internet, but I thought this group may be able to recommend someone to me.
He may be able to help you.
B & K Metal
Kris Hurley
3 Mile Rd. NW Suite E,
Grand Rapids, Mi
(616) 520-3458
PM me for email address.
If you do end up calling him, tell him that Dan Pihlaja sent you.
Although I will say that those tolerances are pretty tight. So your mileage may vary.
- x 2487
- x 1888
Hey Dan,
You may want to remove his email address. This website is publicly available and if you leave it up it'll just cause him to get a bunch of spam. PM the email address, instead.
Anyone needing the email address, please just PM Dan.
I can't help with your request, but I am interested in hearing how this comes out. Doesn't your cylindricity callout greatly exceed your straightness callout? Making a guess, I would not be surprised if breathing on this part will cause it to go out of spec.
