Selecting a Style
Posted: Wed Mar 24, 2021 3:26 pm
by matt
This forum allows you to apply a style, also known as a theme or a skin. This just changes the overall look, colors, icons, and such. There are a few to select from. To set this up, you have to be a registered user and logged in.
Go to the User Control Panel (little triangle next to your user name at the top),
select Board Preferences, and Edit Global Settings
Select one from the list. Also near your user name at the top is the option to select Dark or Light mode. Each style can be shown as dark or light. My screen shots were taken using light mode Supernova style.
Re: Selecting a Style
Posted: Thu Nov 17, 2022 11:18 am
by mgibeault
Hello Matt,
I finally got to register (the question is maybe not so easy for people not verse in American pop rock ;).
But when I'm logged-in I get a bread-and-butter PHP theme instead of the nice one I had before.
Posted: Thu Nov 17, 2022 11:27 am
mgibeault wrote: Thu Nov 17, 2022 11:18 am Hello Matt,
Hey Mr. Gibeault,
This is where you switch between styles:
If you'd like to use the default theme when browsing as a guest, the theme is Elegance I believe.
Posted: Thu Nov 17, 2022 11:31 am
by matt
To change the theme, use the drop down list next to your username and select User Control Panel
Then pick the Board Preferences tab, and switch your "style" to another one. You might have to try several before you find one you like. I personally use the Breeze, but several are nice.
Posted: Thu Nov 17, 2022 11:48 am
by mgibeault
Thanks to both of you!
And you're right Alex, Elegance is the one!
