Dual Units showing same units in sketch
x 2552
x 1401
Hi. I messed something up but cannot find where to fix it. Our primary units are inches. Sometimes I like to show dual dims for some things as it's metric nominal. I turned on dual units and now it shows the secondary in inches as well. I've been searching and cannot find where to set the secondary unit back to mm.
Thank you.
by Shaun » Tue Jan 18, 2022 5:33 am
Hi Ben,
In Document Properties under units I think you can set the dual dimension as below.
Hope this helps you.
Shaun
x 30
x 6
Re: Dual Units showing same units in sketch
Unread post by Shaun »
Hi Ben,
x 2552
x 1401
Shaun wrote: Tue Jan 18, 2022 5:33 am Hi Ben,
Good grief, it was right in front of me, couldn't read. Thank you for kindly pointing out the obvious. I should have went home at 4:30 yesterday...
x 2382
x 2025
Hey Ben,
If you end up "customizing" the units manually on the dimension, then they return to the same unit when they are rounded up. Just a heads up!
