How to prevent sheet metal coordinates being exported to DXF?
Posted: Sun Feb 06, 2022 5:04 am
by Tera
When I export a sheet metal flat pattern as DXF, the coordinates are exported too.
How can I prevent coordinates being exported?
Thank you.
Re: How to prevent sheet metal coordinates being exported to DXF?
Posted: Mon Feb 07, 2022 2:51 am
by RonE
This is probably SPR 1229251 "Sheet Metal - Export DXF DWG - if 'view sketches' is enabled, additional lines are added around the origin".
Please try to check "Views -> Hide / Show -> Hide All Types" before exporting.
Posted: Mon Feb 07, 2022 3:49 am
by Tera
RonE wrote: ↑Mon Feb 07, 2022 2:51 am
That was it. Million thanks.
Problem solved.
I searched for the SPR but couldn't find it. Can you post a link to this SPR?
Thanks again.
Posted: Mon Feb 07, 2022 4:30 am
by RonE
Posted: Mon Feb 07, 2022 4:57 am
by Tera
Customer impact is set to high. At least they know how bothering it is.
We hadn't any problem in 2021 version. I hope they correct it in sp1.
Thanks for the link.
