Disable "Button on default CommandManager tabs has changed in this new version" msg
zwei
x 185
x 600
Unread post by zwei »
Is there anyway to set this msg to "Dont ask again"?
Use copy setting wizard to transfer my shortcuts, macros and customization from SW2019 to SW2020 and this keep poping out everytime SW2020 is launched o[
x 1758
x 2129
Re: Disable "Button on default CommandManager tabs has changed in this new version" msg
I had the same problem a year or two ago. It continued until I updated to the next version.
Answers: 55
x 877
Unread post by JSculley »
Zhen-Wei Tee wrote: Sun Mar 06, 2022 7:33 am Is there anyway to set this msg to "Dont ask again"?
From the Knowledge Base:
S-057905
Question: Why does the error message, ‘The definition of the buttons on the default CommandManager tabs has changed in this new version' display and cannot be dismissed when starting SOLIDWORKS® 2022?
Answer: The CommandManager has changed in SOLIDWORKS® 2022 and the user settings needs to be updated to prevent this dialog from showing up again. Follow these steps:
1. Launch SOLIDWORKS.
2. Go to Tools, add-ins and unload any add-ins that are selected (this can cause the "close Solidworks" issue)
3. Click ok
3a. Open a part, drawing or assembly. Be sure the CommandManager is turned on, and then close SolidWorks
4. Restart SolidWorks
5. If the same message box appears again, dismiss it and repeat steps 3 and 4.
If the problem keeps happening contact your Solidworks reseller for further investigation.
