API Select Printer Paper Size - C#
Jordan Brown
x 6
Unread post by Jordan Brown »
Does anyone have experience with selecting paper size using C#? There is a great macro on Codestack (here) but it uses a VBA function "Device Capabilities" that, according to me reading, does not exist in C#.
Thanks,
Jordan
Answers: 27
x 257
x 432
Re: API Select Printer Paper Size - C#
I know it's not a ton of help, since it's not directly in c#, but you should be able to translate it pretty easily.
The below code picks A (8.5" x 11") and B(11" x 17")
With swModel.PageSetup
    Select Case PaperSize
        Case "A"
            .PrinterPaperSize = 1
            .ScaleToFit = True
            swPSize = 1
        Case "B"
            .PrinterPaperSize = 17
            swPSize = 17
            .ScaleToFit = True
        Case Else
            MsgBox("Error! You must select a page size before printing!")
            Exit Sub
    End Select
End With
This may also help if you haven't looked at it yet.
API Help Page - PageSetup Example c#
x 864
Jordan Brown wrote: Thu Mar 10, 2022 7:06 am Does anyone have experience with selecting paper size using C#? There is a great macro on Codestack (here) but it uses a VBA function "Device Capabilities" that, according to me reading, does not exist in C#.
Thanks,
Jordan
This
Stack Overflow post may help.
