I can't select an edge. Selection filters isn't the issue.
Hazzmatt
x 5
Unread post by Hazzmatt »
See for yourself. When you edit Surface-Loft21, select the Open Group <3>. The line that is co-linear with the purple short line cannot be selected.
1987 Ferrari F40 for forum.SLDPRT
(9.59 MiB) Downloaded 67 times
by zxys001 » Sat Mar 19, 2022 11:38 pm
Hazzmatt wrote: Thu Mar 17, 2022 6:47 pm See for yourself. When you edit Surface-Loft21, select the Open Group <3>. The line that is co-linear with the purple short line cannot be selected.
..something goes south after Surface-Trim38.
..rollback to that and dissect. All the trim's create inaccuracies.
I personally think you are doing too many trim/knit's early on.
..here's a workaround.. create a compcurve before Surface-Trim38
x 600
Re: I can't select an edge. Selection filters isn't the issue.
Interesting... it seem like surface trim 38 is causing the issue? I tried it on my end and seem like it only happen after trim-38.
Maybe a bad vertex/edge?
A little trick i learnt in the past, you can try to copy the two surface (offset=0) and try to re-select the edges using the offset surface again and it may just work
Hazzmatt
x 5
You're right Zhen, the edge can't be selected after that trim 38 even though nothing was trimmed in that area. Very odd. I initially did the offset of 0 but that seemed to cause issues later when trying to knit and create a solid from this. I think its because the loft with the problem edge is a child of other surfaces and when I do an offset and create geometry from it, this creates 2 different sets of dependencies.
zxys001
Answers: 5
x 2305
x 998
Unread post by zxys001 »
Hazzmatt
x 5
That's a great workaround. Thanks, that worked! I didn't even know you could create a comp curve from surface edges. I only think of it as a tool to join sketches.
