Macro to Change Hole Call Out Format
Answers: 26
x 446
x 483
Someone asked on Reddit for a solution to change the hole call out with instances at the end (like below picture. Since there is no direct way, I made a macro to do it. Sharing it if anyone wants to try/use.
Zip file contains macro and macro button BMP file.
Edit: Fixed the macro for single qty hole call out.
Change Hole Call Out Format (SW2022).zip
(19.21 KiB) Downloaded 110 times
x 2489
x 1899
Re: Macro to Change Hole Call Out Format
Nice Deepak!,
Just curious, could this be changed in the calloutformat.txt file to have all holes shown that way? It's been so long since I messed with it but IIRC if you change it there then it should update all holes, correct?
Answers: 26
x 446
x 483
mattpeneguy wrote: Thu Apr 07, 2022 1:39 pm Nice Deepak!,
Unfortunately the instance count position is not controlled by the calloutformat.txt file but it hard codes. So macro is basically moving the instance count to end of the hole call out in the drawing. In case of any changes in the hole (size, qty, etc.), the call out will update and so will be the qty.
x 2489
x 1899
gupta9665 wrote: Fri Apr 08, 2022 12:56 am Unfortunately the instance count position is not controlled by the calloutformat.txt file but it hard codes. So macro is basically moving the instance count to end of the hole call out in the drawing. In case of any changes in the hole (size, qty, etc.), the call out will update and so will be the qty.
Hmm...You had to make that correction over at Reddit, too. Sorry I should have read over there before posting that. Thanks for clarifying.
BTW, I don't see the zip file in your OP (am I missing something?).
Over at Reddit you provide a link to 3DSwym and maybe the file is there. But, I'm guessing most of those Reddit people don't have accounts. But, they can view posts here without an account though. So could you post it here?
Answers: 26
x 446
x 483
mattpeneguy wrote: Fri Apr 08, 2022 8:44 am Over at Reddit you provide a link to 3DSwym and maybe the file is there. But, I'm guessing most of those Reddit people don't have accounts. But, they can view posts here without an account though. So could you post it here?
I had posted the file at both locations so that users can download from either location.
Seems like I forgot to reload the updated macro here, added now. Thank you for pointing that out.
x 2489
x 1899
Thanks Deepak!
