Macro to export GD&T and "separate" them
x 600
I am trying to figure out way(s) to separate the GD&T Exported into the following format
1: GD&T Symbol
2: Tolerance 1
3: Tolerance 2 (if any)
4: Primary Datum
5: Secondary Datum
6: Tertiary Datum
Take the following example :
I had tried a few approach but i cant figure out a proper way to separate them (especially for tolerance 1 and tolerance 2 value)
Method 1: GetTextAtIndex
Result:
GetTextAtIndex(0) = <GTOL-POSI>
GetTextAtIndex(1) = <MOD-DIAM>
GetTextAtIndex(2) = 0.4
GetTextAtIndex(3) = <MOD-MMC>
GetTextAtIndex(4) = A
GetTextAtIndex(5) = B
GetTextAtIndex(6) = <MOD-MMC>
GetTextAtIndex(7) = C
GetTextAtIndex(8) = <MOD-MMC>
Method 2: GetFrameValues+GetFrameSymbols3
Results:
GetFrameValues(1) = 0.4,,A,B<MOD-MMC>,C<MOD-MMC>
GetFrameSymbols3(1) = <GTOL-POSI>, <MOD-MMC>, , , <MOD-MMC>, <MOD-MMC>)
So far i am able to use the GetFrameValues+GetFrameSymbols3 method to get all field as string except Tolerance 1
and Tolerance 2
Any1 is able to help? :?
x 278
x 463
Re: Macro to export GD&T and "separate" them
Can you be more specific as to what you're referring to as "Tolerance 1" and "Tolerance 2"? It's a bit unclear from the information you've given.
If it's referring to the standard +/- tolerance on the actual dimension, you can obtain that through IDimension.Tolerance. If it's referring to something else, please point us in the right direction.
x 600
AlexB wrote: Mon Apr 18, 2022 9:41 am Can you be more specific as to what you're referring to as "Tolerance 1" and "Tolerance 2"? It's a bit unclear from the information you've given.
See example below.
Tolerance 1 is diameter 0 @ MMC
Tolerance 2 is dia 0.05 max
x 278
x 463
The solidworks documentation for GetFrameValues shows that the return values are as follows:
Format of return array of strings is:
retval[0] = Tolerance 1
retval[1] = Tolerance 2
retval[2] = Datum 1
retval[3] = Datum 2
retval[4] = Datum 3
The returns for GetFrameSymbols3 is:
retval[0] = Geometric tolerance symbol
retval[1] = Material condition symbol for first tolerance value
retval[2] = Material condition symbol for second tolerance value
retval[3] = Material condition symbol for datum1
retval[4] = Material condition symbol for datum2
retval[5] = Material condition symbol for datum3
There are empty values in the return arrays that you posted that should be filled with the tolerance2 information if that field is filled out. I'm not able to code an example to verify this right now though.
Austin Schukar
x 288
x 56
It's interesting that they split these up like they do. For the tolerance values, it looks like you have to interrogate GetTextAtIndex manually. I whipped this up and ran some tests, see what you think
Option Explicit
Dim swModelExt As SldWorks.ModelDocExtension
Dim selGtol As SldWorks.Gtol
Dim idx As Long
Dim params As Variant
Dim arrSymbols As Variant
    Set swModel = swApp.ActiveDoc
    Set swModelExt = swModel.Extension
    Set selGtol = swSelMgr.GetSelectedObject6(1, 0)
    Debug.Print "GetTextCount = " & CStr(selGtol.GetTextCount)
Dim gTOLcoll As New Collection
    For idx = 0 To selGtol.GetTextCount - 1
        gTOLcoll.Add selGtol.GetTextAtIndex(idx)
        Debug.Print "GetTextAtIndex(" & CStr(idx) & ") = " & selGtol.GetTextAtIndex(idx)
    Next idx
    Debug.Print "GetFrameCount = " & (CStr(selGtol.GetFrameCount) - 1)
    For idx = 1 To selGtol.GetFrameCount - 1
        params = selGtol.GetFrameValues(idx)
        Debug.Print "GetFrameValues(" & CStr(idx) & ") = " & params(0) & "," & params(1) & "," & params(2) & "," & params(3) & "," & params(4)
        arrSymbols = selGtol.GetFrameSymbols3(idx)
        Debug.Print "  GetFrameSymbols3(" & CStr(idx) & ") = " & arrSymbols(0) & ", " & arrSymbols(1) & ", " & arrSymbols(2) & ", " & arrSymbols(3) & ", " & arrSymbols(4) & ", " & arrSymbols(5) & ")"
   Next idx
    Dim count As Integer
    Dim tol1 As String
    Dim tol2 As String
    Dim item As Variant
    Dim nomTolPassed As Boolean
    nomTolPassed = False
    params = selGtol.GetFrameValues(1)
    arrSymbols = selGtol.GetFrameSymbols3(1)
    gTOLcoll.Remove 1                                               'Remove gTOL symbol from collection
    If arrSymbols(5) <> "" Then gTOLcoll.Remove gTOLcoll.count      'Remove Datum 3 modifier from collection
    If params(4) <> "" Then gTOLcoll.Remove gTOLcoll.count          'Remove Datum 3 from collection
    If arrSymbols(4) <> "" Then gTOLcoll.Remove gTOLcoll.count      'Remove Datum 2 modifier from collection
    If params(3) <> "" Then gTOLcoll.Remove gTOLcoll.count          'Remove Datum 2 from collection
    If arrSymbols(3) <> "" Then gTOLcoll.Remove gTOLcoll.count      'Remove Datum 1 modifier from collection
    If params(2) <> "" Then gTOLcoll.Remove gTOLcoll.count          'Remove Datum 1 from collection
    'Now we should be left with Tolerance 1 and/or Tolerance 2 values. I'm assuming Tolerance 1 exists.
    'Get Tolerance 1
    If params(0) <> "" Then
        For Each item In gTOLcoll
            If count = 0 And (item = "<MOD-DIAM>" Or item = "<MOD-SPHDIA>") Then
                tol1 = tol1 & CStr(item)
                gTOLcoll.Remove 1
                count = count + 1
            ElseIf IsNumeric(item) Then
                gTOLcoll.Remove 1
                nomTolPassed = True
            ElseIf count > 0 And nomTolPassed Then
                If item = "<MOD-DIAM>" Or item = "<MOD-SPHDIA>" Or IsNumeric(item) Then
                    Exit For
                Else
                    gTOLcoll.Remove 1
        Next item
        count = 0
    'Get Tolerance 2
    If params(1) <> "" Then
                tol2 = tol2 & CStr(item)
                gTOLcoll.Remove 1
                count = count + 1
                gTOLcoll.Remove 1
                nomTolPassed = True
                    Exit For
                Else
                    gTOLcoll.Remove 1
        Next item
    Debug.Print tol1
    Debug.Print tol2
Function ToCollection(a As Variant) As Collection
    Dim c As New Collection
    For Each item In a
      c.Add item
    Next item
    Set ToCollection = c
End Function
Sorry for the poor format. I just ripped and butchered the Help example with no mercy.
Austin
x 893
Austin Schukar wrote: Mon Apr 18, 2022 12:39 pm It's interesting that they split these up like they do. For the tolerance values, it looks like you have to interrogate GetTextAtIndex manually.
The tolerance values are in the array returned from GetFrameValues. You have to use this along with GetFrameDiameterSymbols and GetFrameSymbols3 to get the full picture.
A symbol like this:
outputs a set of data like this:
Frame 1 start
	================== Has Diameter Symbol =================
	True
	True
	================== Frame Symbols =================
	<GTOL-PERP>
	<MOD-MMC>
	<MOD-LMC>
	<MOD-LMC>
	<MOD-MMC>
	<MOD-LMC>
	================== Frame Values =================
	0
	.05 MAX
	A<MOD-LMC>
	B<MOD-MMC>
	C<MOD-LMC>
Frame 1 end
The LMC/MMC information associated with the datums appears in both the results from GetFrameSymbols3 and GetFrameValues. The whole IGtol API seems like it was programmed by comittee.
Austin Schukar
x 288
x 56
JSculley wrote: Mon Apr 18, 2022 1:22 pm The tolerance values are in the array returned from GetFrameValues. You have to use this along with GetFrameDiameterSymbols and GetFrameSymbols3 to get the full picture.
A symbol like this:
Frame 1 start
	True
	True
	<GTOL-PERP>
	<MOD-MMC>
	<MOD-LMC>
	<MOD-LMC>
	<MOD-MMC>
	<MOD-LMC>
	0
	.05 MAX
	A<MOD-LMC>
	B<MOD-MMC>
	C<MOD-LMC>
Frame 1 end
I hadn't noticed GetFrameDiameterSymbols...nice!
Where I think the trouble lies is determining where the modifiers are in the frame (specifically, tolerance 1 and tolerance 2). I know I was overthinking it, though.
Austin
x 600
A symbol like this:
Frame 1 start
	True
	True
	<GTOL-PERP>
	<MOD-MMC>
	<MOD-LMC>
	<MOD-LMC>
	<MOD-MMC>
	<MOD-LMC>
	0
	.05 MAX
	A<MOD-LMC>
	B<MOD-MMC>
	C<MOD-LMC>
Frame 1 end
Nice!
Just one last question... using GetFrameDiameterSymbols seem to return TRUE for both cylindrical and spherical tolerance zone, is there anyway to determine whether it is a cylindrical or spherical modifier (<MOD-DIAM>0 vs <MOD-SPHDIA>)?
