Can a section view of flattened image be appearing off?
Ömür Tokman
x 995
x 347
Unread post by Ömür Tokman »
Hello friends,
What I want to do is take a closed view section from a flattened view. for now i am doing this tricky way but i am looking for an easier(fast9 way).
AngryPictureDrawer2
x 12
x 14
Re: Can a section view of flattened image be appearing off?
Unread post by AngryPictureDrawer2 »
That looks like just a simple projected view.
you can use the section tool of you want, change the configuration in the section view to match the flat pattern view or "use Parent"
SamSpade
x 223
x 155
Unread post by SamSpade »
Hi Omar, I too have been searching for a while to come up with a solution to that same issue. Essentially, to achieve that type of layout I pretty much perform these steps. I gather it is close, if not identical, to your first method.
-I start off by adding the view in its modeled state (top view)
-create the section views off of that
-hide the initial view (but keep the dependent section views visible)
-break the alignments for the section views
-insert the flattened development view
-and finally recreate the alignments between the flattened view and the section views.
This process works but I guess not ideal.
x 2384
x 2025
Use projected views and switch the projected views from the flat pattern config to the default config, and voila!
Edit: Here's an example, we do this!
SamSpade
x 223
x 155
AlexLachance wrote: Tue May 17, 2022 10:08 am Use projected views and switch the projected views from the flat pattern config to the default config, and voila!
Hi Alex, that does work great for projections views, but unfortunately doesn't apply when using section views.
x 2384
x 2025
SamSpade wrote: Tue May 17, 2022 10:33 am Hi Alex, that does work great for projections views, but unfortunately doesn't apply when using section views.
Understood!
Why not proceed as such?
Edit: To clarify what I mean:
Have folded views that show all the profiles needed shown.
Have a flat pattern view
Include a 3D view to make sure it's clear for the guy on the shop floor
If working this way causes any sort of confusion, a note under the flat pattern wouldn't clear whatever confusion there is..?
x 2384
x 2025
Perhaps, if it's to clarify the folding process, you could create sub-configs to show the partial folding done?
