How does one use swCenterMarkConnectionLine_e Enumeration?
loeb
x 40
x 12
Unread post by loeb »
I am working on some macros that gets and sets document properties for CenterMarks and gets and sets properties of CenterMarks themselves. I am trying to manipulate the settings around Circular Lines, Radial Lines, and Base Center Mark. I found the enumeration regarding this setting here:
https://help.solidworks.com/2021/englis ... ine_e.html
but I can't figure out how to use it?
Thank You,
colt
x 14
x 22
Re: How does one use swCenterMarkConnectionLine_e Enumeration?
Unread post by colt »
Not sure if it is a setting, but might only be available while performing an auto insert...
https://help.solidworks.com/2017/Englis ... arks2.html
Add together the options you want from swCenterMarkConnectionLine_e and then apply to the InsertOption field.
