Freeze Bar macro?
Library for macros
ellundo
x 18
Freeze Bar macro?
Unread post by ellundo »
I am looking for a macro that would run through all the parts in an assembly and activate the freeze bar on all the parts in the assembly. Does anyone have one for this that they could share?
x 600
Re: Freeze Bar macro?
Freeze bar should be a system option which you only need to turn on once for it to appear on all part.
If you are referring to moving the freeze bar, the example should get you started:
https://help.solidworks.com/2017/Englis ... ple_VB.htm
Answers: 26
x 445
x 469
Zhen-Wei Tee wrote: Thu May 26, 2022 8:15 am Freeze bar should be a system option which you only need to turn on once for it to appear on all part.
But that will appear on the top only and I think OP is looking to pull it to end of tree.
x 2489
x 1899
I haven't looked at the macro I made/borrowed in a while, but I apparently have one at the link below that rolls the bar up and down the tree:
viewtopic.php?t=74
Answers: 26
x 445
x 469
ellundo wrote: Thu May 26, 2022 7:21 am I am looking for a macro that would run through all the parts in an assembly and activate the freeze bar on all the parts in the assembly. Does anyone have one for this that they could share?
Try the macros from this post https://r1132100503382-eu1-3dswym.3dexp ... fF45wHju5w
