I made a SolidWorks Add-In program in C# and try to make an installer for the Add-In. I use Microsoft Visual Studio 2022 community edition and tried both the Microsoft Installer and WIX. Everything goes fine and the Add-In is listed in the SolidWorks Add-In dialog box. However, if I check my Add-in in the Add-In dialog box, my Add-In is not loaded, and the checkbox is unchecked automatically. If I keep the original Add-In DLL that is generated by the Visual Studio in its output folder, SolidWorks finds that DLL and loads it instead. If I delete the original Add-In DLL (not the installed DLL), then SolidWorks won't find and load the installed Add-In DLL (that is installed on C:\Program Files). I checked the Windows registry, and it looks like all information is correct in the registry. What am I missing?
Thank you
YS
SolidWorks API Add-In installer problem
Re: SolidWorks API Add-In installer problem
This write-up that Artem put together helped me get things working with my add-in. Hopefully it help you too.
https://www.codestack.net/solidworks-ap ... aller/wix/
Thank you for your reply. That article is exactly what I followed, but the add-in is not loaded when it is installed on a new computer. It works fine in the development computer as the DLL is loaded from the DLL output from the Visual studio.AlexB wrote: ↑Sat May 28, 2022 11:59 pm This write-up that Artem put together helped me get things working with my add-in. Hopefully it help you too.
Good to see you found the article already. Are you using the "Approach A: Post build action" to register your project's COM components? If so, is this inside your WIX <Feature> tag as a <ComponentGroupRef> to tell it to register these when installing? The description of your problem sounds like it's caused by an improperly registered DLL so I would begin looking at the DLL registration portion of the install. I ran into something similar and ended up generating all new GUIDs for my installer's <ComponentGroup> fields and everything worked.
At the risk of being Captain Obvious here; the two things that burn me over an over:
1: Project Properties -> Build tab, Platform target: set it to 64 bit or at least >uncheck "Prefer 32-bit" CAD stuff has been all 64 bit for a couple years now, no need to compile for 32 that I know of.
2: Project References, Solidworks Library (or whatever software's API you're using) Embed Interop Types should usually be set to False.
Yes, those are included. I checked my Product.wxs with the one on the website line by line. There must be something missing or wrong but I cannot find it.AlexB wrote: ↑Tue May 31, 2022 8:42 am Good to see you found the article already. Are you using the "Approach A: Post build action" to register your project's COM components? If so, is this inside your WIX <Feature> tag as a <ComponentGroupRef> to tell it to register these when installing?
When running Solidworks, the Splash windows shows that the add-in is loading. The add-in is listed in the Add-In dialog box (Tools > Add-In). When I hover my mouse over the add-in item listed in the dialog box, however, the tool-tip pops up showing the Visual Studio output folder, not the installation folder. I don't know how to let SolidWorks load the add-in DLL from the installed directory.
Thank you for your input. Yes, I set 64bit, and all are set to False.bnemec wrote: ↑Tue May 31, 2022 10:36 am At the risk of being Captain Obvious here; the two things that burn me over an over:
