PDM API Drawing Node
Posted: Tue Jun 07, 2022 3:45 pm
by Emra
Hi everyone,
I frequently want to get a handle for the drawing of a specific part (or vice versa) in order to sync PDM variable values, but there doesn't seem to be a clean way to get a drawing hook (similar to the "Open Drawing" button for a given part) through API. Anyone want to tell me I'm wrong and there's an obvious way to do this?
For reference, I do have a functioning workaround of scanning the reference tree for immediate parent with a file extension of "slddrw" (shown below), so this isn't a blocker so much as a "why is it like this" question. It just feels like a circuitous and inefficient way to get something that should be simple - building the ref tree seems to take a long time, especially if you're processing multiple files - and I'm hoping someone on here has a better solution.
    Function GetDrawingId(ByVal targetFile As IEdmFile17) As Integer
        Dim drawingID As Integer = Nothing
        Dim fPos As IEdmPos5 = targetFile.GetFirstFolderPosition
        Dim folder As IEdmFolder12 = targetFile.GetNextFolder(fPos)
        Dim refTree As IEdmReference11 = targetFile.GetReferenceTree(folder.ID)
        Dim rPos As IEdmPos5
        Dim refFile As IEdmFile17
        Dim ext As String
        rPos = refTree.GetFirstParentPosition2(0, False, EdmRefFlags.EdmRef_File)
        Dim parentRef As IEdmReference11
        While Not rPos.IsNull
            parentRef = refTree.GetNextParent(rPos)
            refFile = parentRef.File
            ext = Right(refFile.Name, refFile.Name.Length - refFile.Name.LastIndexOf(".") - 1)
            If ext.ToLower.Equals("slddrw") Then
                drawingID = refFile.ID
                Return drawingID
            End If
        End While
        Return drawingID
    End Function
Thanks in advance for any suggestions!
Re: PDM API Drawing Node
Posted: Tue Jun 07, 2022 4:42 pm
by Jordan Brown
A cheaters way that I have used before is to get the file path of the part as a string and then change the .sldprt extension to .slddrw.
As long as the part and drawing are in the same folder it works fine. If not it breaks down.
Posted: Tue Jun 07, 2022 5:38 pm
by Emra
Jordan Brown wrote: Tue Jun 07, 2022 4:42 pm A cheaters way that I have used before is to get the file path of the part as a string and then change the .sldprt extension to .slddrw.
Thanks for the reply!
I might try that as a shortcut - it should work the majority of the time if the drawing exists, and then I could use the ref tree strategy as a backup if there's no .slddrw in the same folder. Doesn't solve the wasted computation of scanning the whole ref tree if the drawing doesn't exist at all yet, though... I was really hoping that there was a way to just get the drawing node directly; the info is definitely there, just not accessible via API.
