Step files only surfaces?
VTmechie
x 16
Unread post by VTmechie »
I am trying to import the bracket on this inductor:
https://magnetic-components.mpsind.com/ ... p1655b-200
It imports as surfaces only. Is there an easy way to make this a model with solid bodies?
zxys001
Answers: 5
x 2304
x 997
Re: Step files only surfaces?
Unread post by zxys001 »
VTmechie wrote: Mon Jun 13, 2022 2:52 pm I am trying to import the bracket on this inductor:
Hi VTmechie,
So, it looks like your import settings are not set for Stitching?
If you set to stitch, you still will not get a clean solid, because, the data does not include some of the surfaces (I checked in two other software)
With what I get, the fast way is just RMB over the bracket surface and select Tangency and Offset 0 and Thicken 1mm.
VTmechie
x 16
Thank you zxys001! I got it to work. Just enough info to guide me. Love this board.
