The Ultimate Guide for Working with STEP Files
Alin
x 265
x 391
Unread post by Alin »
Alin
x 265
x 391
Re: The Ultimate Guide for Working with STEP Files
Alin wrote: Wed Jun 15, 2022 9:34 am Have just added one more chapter to the STEP saga:
The Ultimate Guide to Working with STEP Files, Part 1: The Battle of Two Import Engines – Quality and Speed
https://www.engineersrule.com/the-ultim ... and-speed/
The Ultimate Guide to Working with STEP Files, Part 2: Working with Revised STEP Files
https://www.engineersrule.com/the-ultim ... tep-files/
The Ultimate Guide to Working with STEP Files, Part 3: Geometry Comparison for Revised STEP Files
The Ultimate Guide to Working with STEP Files, Part 4: Simplification Techniques for Complex Imported Geometry Imported as Assemblies
https://www.engineersrule.com/the-ultim ... ssemblies/
The Ultimate Guide to Working with STEP Files, Part 5A: Simplification Techniques for Complex Imported Geometry Imported as Multibody Parts
https://www.engineersrule.com/the-ultim ... ody-parts/
The Ultimate Guide to Working with STEP Files, Part 5B: Simplification Techniques for Complex Imported Geometry Imported as Multibody Parts
Feel free to replace "STEP" with any other word implying a file format that could be imported in SOLIDWORKS.
berg_lauritz
Answers: 6
x 439
x 233
Unread post by berg_lauritz »
This macro might be very helpful to you too.
What I use it for:
  • Move bodies around & re-save to have it at the corrected position (i.e. if you get a step file where something is slightly angled (and you know it should not be) or when you want to adjust the main planes to your gusto).
  • You can modify the step file without having to fear to use features!
  • Instead of using the very slow, cumbersome and not very fail proof approach to i.e. delete fillets from an imported body you can simply use 'delete face' now & re-save it again.
  • Importing geometry with feature recognition does not yield weird planes/views anymore because you can adjust the standard planes. And you can modify it before with all your standard tools....
  • I think you could even upgrade the macro to keep the face IDs to make it even more powerful.
I wanted to make a video for a long time now but I never found the time. Maybe this weekend.
Edit: I just made a quick .gif of how I have to work sometimes. I hope this clarifies some things @Alin :
Edit2: Just thought of another HUGE benefit of this: If you modify something you can run import diagnostics AFTER you added some features & reduced it back to imported bodies only. This is often very beneficial when you i.e. know you have to modify the purchased part and the failed imported surfaces/bodies are going to be removed by you anyway.
You can also make sketches from the original part (convert entities, offset surfaces etc.) & then reduce it back to 'imported geometry' only. It's incredibly powerful, I think.
Edit3: Just read the article - nice work!
Alin
x 265
x 391
berg_lauritz wrote: Wed Jun 15, 2022 12:52 pm This macro might be very helpful to you too.
I love it!!! This should be part of the SW functionality.
Many thanks!
berg_lauritz
Answers: 6
x 439
x 233
Alin wrote: Thu Jun 16, 2022 8:29 pm I love it!!! This should be part of the SW functionality.
Many thanks!
I agree. Can you push for an SR?
Alin
x 265
x 391
berg_lauritz wrote: Fri Jun 17, 2022 8:59 am I agree. Can you push for an SR?
Would be nice to add the functionality to include the surface bodies.
