Bit Locker Recovery Key
Computers, video cards, laptops, mice, spaceballs, network equipment...
x 383
x 415
Anyone know a way/software to decrypt a SSD locked with lost Bit Locker Recovery Key?
x 2185
x 1886
Re: Bit Locker Recovery Key
I'm sure you've already used google, but just in case
https://www.easeus.com/data-recovery/lo ... y-key.html
The article speaks of a program called EaseUS Data Recovery Wizard that could also do what you need, though I've never tried it myself.
Tom G
x 999
x 468
Unread post by Tom G »
AlexLachance wrote: Wed Jun 29, 2022 7:51 am The article speaks of a program called EaseUS Data Recovery Wizard that could also do what you need, though I've never tried it myself.
I've used EaseUS Data Recovery Wizard 14 years ago, before BitLocker existed. Good software, if rarely used. We had a NAS cease to function which had all our project files on it, and recovered nearly all of it. I am unfamiliar with it since, but it should have instructions if it is capable of decrypting BL.
x 383
x 415
Thanks Tom for sharing your experience. Already tried it and it doesn't work with BL.
x 383
x 415
AlexLachance wrote: Wed Jun 29, 2022 7:51 am I'm sure you've already used google, but just in case
Already went thru those steps and no result. Thank you for sharing though.
zxys001
x 2270
x 974
Unread post by zxys001 »
gupta9665 wrote: Wed Jun 29, 2022 2:52 pm Already went thru those steps and no result. Thank you for sharing though.
Can you hook the drive up or better, boot the drive on the original hardware it was created?
x 383
x 415
zxys001 wrote: Sat Jul 02, 2022 8:43 pm Can you hook the drive up or better, boot the drive on the original hardware it was created?
Thanks Paul for commenting, the drive is still inside the original hardware.
zxys001
x 2270
x 974
gupta9665 wrote: Sun Jul 03, 2022 1:27 am Thanks Paul for commenting, the drive is still inside the original hardware.
Hello Deepak, so, none of the online workarounds are working?
x 2185
x 1886
Hopefully Paul or someone else can find a solution for someone who provides so many solutions to the community.
Answers: 13
x 2038
x 1702
If bitlocker is effective at doing what it claims to do, there won't be an easy way to defeat the security without the key.
x 2185
x 1886
SPerman wrote: Mon Jul 04, 2022 8:31 am If bitlocker is effective at doing what it claims to do, there won't be an easy way to defeat the security without the key.
Indeed, but searching the internet seems to reveal that the program had a number of issues also, so perhaps someone developped something in regards to that.
Answers: 13
x 2038
x 1702
There is certainly no shortage of security products that fail spectacularly at their job.
x 383
x 415
zxys001 wrote: Sun Jul 03, 2022 3:35 pm Hello Deepak, so, none of the online workarounds are working?
Thanks Paul but most workarounds/software are asking for the recovery key which I do not have :roll:
I'm trying other methods and will post the update once there is a progress.
x 1547
x 1396
You need the key or password to decrypt.
I tried Bitlocker, its so slow on USB drives.
I end up bought a WD passport with hardware encryption.
WD has SSD with hardware encryption also.
x 1547
x 1396
Good read: https://github.com/e-ago/bitcracker
And good luck
