Save weldment as assembly macro
Wasermelone
Unread post by Wasermelone »
Hi everyone, I'm trying to write a macro that would save part that is made from weldments as an assembly. I'm trying to use the CreateSaveBodyFeature method but can't get it to work, it seems that I don't fully understand how this method works. Maybe someone knows a better solution on how to achieve this? Any help would be nice and greatly appreciated!
ajberinguela
Re: Save weldment as assembly macro
Unread post by ajberinguela »
Hi, I'm looking for the same thing, do you have any updates on this one? Thank you in advance
Answers: 26
x 444
x 468
ajberinguela
Thanks Gupta, this is close enough. However, there are still isssues I need to address.
-It works for solid bodies but not for the cut list.
-I want to use the Cut List folder name as the file name
-I want to maintain the color that is set during the creation of the part.
Answers: 26
x 444
x 468
ajberinguela wrote: Mon Sep 02, 2024 8:31 pm Thanks Gupta, this is close enough. However, there are still isssues I need to address.
You may check this post for macro to cover 1 and 2 https://r1132100503382-eu1-3dswym.3dexp ... 7kcoePa9GQ
Unfortunately color option is not yet supported by API. So raise Enhancement Request (ER) for it.
ajberinguela
Thanks! This is a big help. If the API doesn’t support colors, do you have any workaround ideas?
Answers: 26
x 444
x 468
You can try getting the color for each body into an array. And once bodies are exported as parts, you can reapply the colors to them with values from the array.
ajberinguela
Thank you, this is a macro that let's me saved the colors into an array. The next one is a macro I get from CodeStack that let's me put colors in part in random. Is there a way I can combine these two?
Option Explicit
Sub GetBodyColors()
Dim swPart As SldWorks.PartDoc
Dim swBody As SldWorks.Body2
Dim vBodies As Variant
Dim vMatProp As Variant
Dim i As Integer
Dim bodyColors() As String
Set swModel = swApp.ActiveDoc
Set swPart = swModel
' Get all bodies in the part
vBodies = swPart.GetBodies2(swAllBodies, False)
' Resize the array to hold the colors
ReDim bodyColors(UBound(vBodies))
' Loop through each body and get its color
For i = 0 To UBound(vBodies)
Set swBody = vBodies(i)
vMatProp = swBody.MaterialPropertyValues2
If Not IsEmpty(vMatProp) Then
bodyColors(i) = "RGB(" & vMatProp(0) * 255 & ", " & vMatProp(1) * 255 & ", " & vMatProp(2) * 255 & ")"
Else
bodyColors(i) = "No color"
Next i
' Show a message box indicating that the colors have been stored
MsgBox "Colors stored in array"
______________________________________________________________________________________
'Copyright(C) 2024 Xarial Pty Limited
'Reference: https://www.codestack.net/solidworks-ap ... -assembly/
'License: https://www.codestack.net/license/
Const COMP_LEVEL As Boolean = False
Const PARTS_ONLY As Boolean = False
Const ALL_CONFIGS As Boolean = False
Const PRP_NAME As String = ""
Dim ColorsMap As Object
Sub InitColors(Optional dummy As Variant = Empty)
ColorsMap.Add "Plate", RGB(255, 0, 0)
ColorsMap.Add "Beam", RGB(0, 255, 0)
try_:
On Error GoTo catch_
Set ColorsMap = CreateObject("Scripting.Dictionary")
ColorsMap.CompareMode = vbTextCompare
InitColors
If Not swModel Is Nothing Then
If swModel.GetType() = swDocumentTypes_e.swDocASSEMBLY Then
Dim swAssy As SldWorks.AssemblyDoc
Set swAssy = swModel
swAssy.ResolveAllLightWeightComponents True
Dim vComps As Variant
vComps = swAssy.GetComponents(False)
ColorizeComponents vComps
swModel.GraphicsRedraw2
Else
Err.Raise vbError, "", "Only assembly document is supported"
Else
Err.Raise vbError, "", "Open assembly document"
GoTo finally_
catch_:
MsgBox Err.Description, vbCritical
finally_:
Sub ColorizeComponents(vComps As Variant)
Dim i As Integer
Dim processedDocs() As String
For i = 0 To UBound(vComps)
Dim swComp As SldWorks.Component2
Set swComp = vComps(i)
Dim swRefModel As SldWorks.ModelDoc2
Set swRefModel = swComp.GetModelDoc2()
If Not swRefModel Is Nothing Then
If Not PARTS_ONLY Or swRefModel.GetType() = swDocumentTypes_e.swDocPART Then
Dim docKey As String
docKey = LCase(swRefModel.GetPathName())
If Not ALL_CONFIGS Then
docKey = docKey & ":" & LCase(swComp.ReferencedConfiguration)
If COMP_LEVEL Or Not Contains(processedDocs, docKey) Then
If (Not processedDocs) = -1 Then
ReDim processedDocs(0)
Else
ReDim Preserve processedDocs(UBound(processedDocs) + 1)
processedDocs(UBound(processedDocs)) = docKey
Dim color As Long
color = RGB(Int(255 * Rnd), Int(255 * Rnd), Int(255 * Rnd))
If PRP_NAME <> "" Then
Dim prpVal As String
prpVal = GetModelPropertyValue(swRefModel, swComp.ReferencedConfiguration, PRP_NAME)
If prpVal <> "" Then
If ColorsMap.Exists(prpVal) Then
color = ColorsMap(prpVal)
Else
ColorsMap.Add prpVal, color
Dim RGBHex As String
RGBHex = Right("000000" & Hex(color), 6)
Dim dMatPrps(8) As Double
dMatPrps(0) = CInt("&H" & Mid(RGBHex, 5, 2)) / 255
dMatPrps(1) = CInt("&H" & Mid(RGBHex, 3, 2)) / 255
dMatPrps(2) = CInt("&H" & Mid(RGBHex, 1, 2)) / 255
dMatPrps(3) = 1
dMatPrps(4) = 1
dMatPrps(5) = 0.5
dMatPrps(6) = 0.3125
dMatPrps(7) = 0
dMatPrps(8) = 0
If COMP_LEVEL Then
swComp.SetMaterialPropertyValues2 dMatPrps, IIf(ALL_CONFIGS, swInConfigurationOpts_e.swAllConfiguration, swInConfigurationOpts_e.swThisConfiguration), Empty
Else
Dim sConfs(0) As String
sConfs(0) = swComp.ReferencedConfiguration
swRefModel.Extension.SetMaterialPropertyValues dMatPrps, IIf(ALL_CONFIGS, swInConfigurationOpts_e.swAllConfiguration, swInConfigurationOpts_e.swSpecifyConfiguration), IIf(ALL_CONFIGS, Empty, sConfs)
swRefModel.SetSaveFlag
Next
Function GetModelPropertyValue(model As SldWorks.ModelDoc2, confName As String, prpName As String) As String
Dim swCustPrpMgr As SldWorks.CustomPropertyManager
Set swCustPrpMgr = model.Extension.CustomPropertyManager(confName)
prpVal = GetPropertyValue(swCustPrpMgr, prpName)
If prpVal = "" Then
Set swCustPrpMgr = model.Extension.CustomPropertyManager("")
GetModelPropertyValue = prpVal
End Function
Function GetPropertyValue(custPrpMgr As SldWorks.CustomPropertyManager, prpName As String) As String
Dim resVal As String
custPrpMgr.Get2 prpName, "", resVal
GetPropertyValue = resVal
End Function
Function Contains(arr() As String, item As String) As Boolean
If (Not arr) <> -1 Then
Dim i As Integer
For i = 0 To UBound(arr)
If arr(i) = item Then
Contains = True
Exit Function
Next
Contains = False
End Function
