Asking around before i start writing my own macro...
Do anyone has a macro or similar macro that do the following?
The current idea for the workflow is that:
1. Select TWO component in feature tree
2. Run the macro
3. The macro mate the two component together using origin
Macro to Mate Origin - Origin
I contacted API Support and they suggest using AddMate5 with swMateCOORDINATE, which will align the axes.
The code snippet below works as expected. Have fun with it
Go to full postThe code snippet below works as expected. Have fun with it
Dim swAsm As SldWorks.AssemblyDoc
Dim swSketch As SldWorks.Sketch
Dim swSkPoint As SldWorks.SketchPoint
Dim SelComps(1) As Object
Dim i As Integer
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then MsgBox "Please open a Assembly!": End
If swModel.GetType <> swDocASSEMBLY Then MsgBox "Please open a Assembly!": End
Set swAsm = swModel
Set SelComps(0) = swSelMgr.GetSelectedObjectsComponent(1)
Set SelComps(1) = swSelMgr.GetSelectedObjectsComponent(2)
If swSelMgr.GetSelectedObjectCount2(-1) > 2 Then MsgBox "Please select only two components!": End
If swSelMgr.GetSelectedObjectCount2(-1) <> 2 Then MsgBox "Please select two components!": End
If SelComps(0) Is Nothing Or SelComps(1) Is Nothing Then MsgBox "Please select two components!": End
swModel.ClearSelection2 True
For i = 0 To 1
Set swFeat = SelComps(i).FirstFeature
Do While Not swFeat Is Nothing
If "OriginProfileFeature" = swFeat.GetTypeName Then
Set swSketch = swFeat.GetSpecificFeature2
Set swSkPoint = swSketch.GetSketchPoints2()(0)
swSkPoint.Select4 True, Nothing
Exit Do
Loop
Next i
swAsm.AddMate5 20, -1, False, 0, 0, 0, 0, 0, 0, 0, 0, False, False, 0, Empty
swModel.EditRebuild3
- Stefan Sterk
- x 51
- x 77
Re: Macro to Mate Origin - Origin
Hi Zhen,
The code that follows fulfills your request. The only issue I can identify is that the Origin Axes don't align as they would if I did it manually.
Dim swSelComp As SldWorks.Component2
Dim swSelComp1 As SldWorks.Component2
Dim swSelComp2 As SldWorks.Component2
Dim swCoincMateData As SldWorks.CoincidentMateFeatureData
Dim EntitiesToMate(1) As Object
Dim EntitiesToMateVar As Variant
Dim i As Integer
Set swAsm = swModel
Set swSelComp1 = swSelMgr.GetSelectedObjectsComponent(1)
Set swSelComp2 = swSelMgr.GetSelectedObjectsComponent(2)
' Check selection
If swSelComp1 Is Nothing Or swSelComp2 Is Nothing Then MsgBox "Please select two components!": End
' Get origins to mate
For i = 0 To 1
Set swSelComp = swSelMgr.GetSelectedObjectsComponent(i + 1)
Set swFeat = swSelComp.FirstFeature
Set EntitiesToMate(i) = swSkPoint
Exit Do
Loop
Next i
EntitiesToMateVar = EntitiesToMate
' Create CoincidentMateFeatureData
Set swCoincMateData = swModel.CreateMateData(0)
swCoincMateData.EntitiesToMate = (EntitiesToMateVar)
swCoincMateData.MateAlignment = 0
swModel.CreateMate swCoincMateData
- Stefan Sterk
- x 51
- x 77
Dim i As Integer
Set swAsm = swModel
For i = 0 To 1
Exit Do
Loop
Next i
- x 2361
- x 2011
Hey guys, just stopping by to hola at both of you!
Sorry for the late reply... This totally slipped my mind after my vacation...Stefan Sterk wrote: ↑Fri Jul 08, 2022 6:22 am I contacted API Support and they suggest using AddMate5 with swMateCOORDINATE, which will align the axes.
Sub main() Dim swApp As SldWorks.SldWorks Dim swModel As SldWorks.ModelDoc2 Dim swAsm As SldWorks.AssemblyDoc Dim swSelMgr As SldWorks.SelectionMgr Dim swFeat As SldWorks.Feature Dim swSketch As SldWorks.Sketch Dim swSkPoint As SldWorks.SketchPoint Dim SelComps(1) As Object Dim i As Integer Set swApp = Application.SldWorks Set swModel = swApp.ActiveDoc If swModel Is Nothing Then MsgBox "Please open a Assembly!": End If swModel.GetType <> swDocASSEMBLY Then MsgBox "Please open a Assembly!": End Set swAsm = swModel Set swSelMgr = swModel.SelectionManager Set SelComps(0) = swSelMgr.GetSelectedObjectsComponent(1) Set SelComps(1) = swSelMgr.GetSelectedObjectsComponent(2) If swSelMgr.GetSelectedObjectCount2(-1) > 2 Then MsgBox "Please select only two components!": End If swSelMgr.GetSelectedObjectCount2(-1) <> 2 Then MsgBox "Please select two components!": End If SelComps(0) Is Nothing Or SelComps(1) Is Nothing Then MsgBox "Please select two components!": End swModel.ClearSelection2 True For i = 0 To 1 Set swFeat = SelComps(i).FirstFeature Do While Not swFeat Is Nothing If "OriginProfileFeature" = swFeat.GetTypeName Then Set swSketch = swFeat.GetSpecificFeature2 Set swSkPoint = swSketch.GetSketchPoints2()(0) swSkPoint.Select4 True, Nothing Exit Do End If Set swFeat = swFeat.GetNextFeature Loop Next i swAsm.AddMate5 20, -1, False, 0, 0, 0, 0, 0, 0, 0, 0, False, False, 0, Empty swModel.EditRebuild3 swModel.ClearSelection2 True End Sub
The macro work like a charm
Thanks a lot.
I was trying addmate5 for a while and the answer helped me to understand the problem was the axis alignment required an undocumented "-1" after the swMateCOORDINATE "20". lol
Thank you!
https://help.solidworks.com/2024/Englis ... Redirect=1
Member Description
swAlignAGAINST Obsolete. Do not use.
swAlignNONE Obsolete. Do not use.
swAlignSAME Obsolete. Do not use.
swMateAlignALIGNED 0
swMateAlignANTI_ALIGNED 1
swMateAlignCLOSEST 2
Thank you!
Member Description
