Step file saved from Fusion360
- x 1761
- x 2132
I can't open it. I get the error below when I try (I erased part of it, which included the client and product name, but it was just the rest of the file path for the folder where I saved it). The file name has v9 in it, if that helps.
He said he doesn't have an option to save as parasolid. Is that correct? Or does anyone have any ideas?
As you might have guessed, it's proprietary, so I can't share the file.
Re: Step file saved from Fusion360
You could have him try iges. I've had times where one worked better than the other.
- x 1643
- x 1471
Ask client to save it as AP203 STEP
- x 1643
- x 1471
https://knowledge.autodesk.com/support/ ... solidworks
To correct the error, try the following
Deactivate “3D interconnect” in SOLIDWORKS Options > System Options > Import.
Open the STEP file using a text editor such as Notepad. The file will open as text.
Use Search/Find, and search for: PRESENTATION_STYLE_ASSIGNMENT.
If this problematic data is found, replace it using the Search/Find & Replace command with: PRES.
- x 1643
- x 1471
Post the "FILE_SCHEMA" line. It show STEP version.FILE_SCHEMA (('AUTOMOTIVE_DESIGN { 1 0 10303 214 3 1 1 }'));
The one I posted above is 214 rev 10303.
This is 203.FILE_SCHEMA (('CONFIG_CONTROL_DESIGN'));
- x 1761
- x 2132
He said he didn't see an option to save it as AP203.
He saved it as iges and sent that. The hardware came in with errors, but it was easy enough to delete those few parts and use mine, so I'm good to go. Thanks.
Thankfully I only have to deal with other people's files about once every five years.
- x 1643
- x 1471
That was daily on last job. 400+ parts. Photo hunt on every update.
- zxys001
- x 2305
- x 998
Why not ACIS? Their kernel (Shape manager) is a fork of ACIS (version 7?) and a precise brep modeler like Parasolid.Glenn Schroeder wrote: ↑Tue Jul 26, 2022 8:45 am He said he didn't see an option to save it as AP203.
- x 1761
- x 2132
I have no idea.
