questions about Revision Tables
Mike Gera
x 98
x 40
Unread post by Mike Gera »
Up until now, I've been using line and text-based revision tables. Pretty barbaric. And not efficient.
I'd like to start using proper Revision Tables.
I have a few questions:
1. How do I set the table growth direction to "up"? Meaning: I want the column headers on the bottom and new rows to go above it.
2. How do I edit the table in Excel? Is this possible?
3. How can I have the table that appears on Sheet 1 (and is edited on Sheet 1) mirror on subsequent sheets?
4. Does the Revision Table typically go on the Sheet, or the Sheet Format? I prefer it on the Sheet Format.
Thanks for any replies.
by zwei » Tue Aug 02, 2022 9:31 pm
1. Change the table header top to table header bottom. Your rev table will be flipped vertically
2. I dont think it is editable in Excel
3. Under Document Properties → Table → Revision, select Linked for Multiple Sheet Style
4. This depends on your use case. In your case, embedding in sheet format might be a better option if you want the rev table to show up on all sheet
Edit: Rev table could NOT be inserted into sheet format. See comment below
SW 2024 SP 5.0
Windows 11
x 600
Re: questions about Revision Tables
Mike Gera
x 98
x 40
This was extremely helpful.
Thank you, Zhen-Wei Tee.
SW 2024 SP 5.0
Windows 11
Mike Gera
x 98
x 40
One question, though.
How do I embed a Revision Table into a sheet format?
Insert, Tables, Revision Table is grayed out when editing a sheet format.
Thanks.
SW 2024 SP 5.0
Windows 11
x 600
Mike Gera wrote: Wed Aug 03, 2022 7:26 am One question, though.
Thanks.
Sorry, i think i remember wrongly.
Rev Table could not be added onto sheetformat. It need to be added into the drawing template
Mike Gera
x 98
x 40
Zhen-Wei Tee wrote: Wed Aug 03, 2022 8:06 am Sorry, i think i remember wrongly.
Got it. Thanks.
SW 2024 SP 5.0
Windows 11
