Force referenced documents to save to current version
You can improve save performance by clearing the Force referenced documents to save to current version system option in the External References tab.
When you clear the option, only documents that are modified in the current session are saved to the current version of
SOLIDWORKS. This reduces save times significantly on the first save of large assemblies and drawings.
What i am really interested is the ability to NOT save the not-modified file into the latest version.
For instance, I could use a SWx2017 screw/standard part in a SWx2017 assembly and a SWx2021 assembly at the same time without needing to save it into new version.
As we are using multiple SWx version for different project (eg: SWX 2018, 2019, 2020, etc), with this option, this seems like it will be much easier to work with mixed version files, particularly on using standard fastener file.
Do anyone has any good experience working with mixed version files (eg: mixing SWX2019 and SWX2020) that you could share?
