I have this file where I enter the units as inches for a global variable it's doing a conversion as if I entered them in metric when I try to use the variable. File units are set to IPS, but SW is altering my 1in = .0254 when I try to use the global variable.
Anyone know how to fix this?
Here's a video showing what I mean:
I have also attached the file...Frustrating...
Global Variable Units Not Working
- x 2487
- x 1888
- R2-H.002264 M05 End Wedge Base 10inch Ramp.SLDPRT
- (127.92 KiB) Downloaded 31 times
- x 1652
- x 2058
Re: Global Variable Units Not Working
It worked fine for me. I started a new sketch, inserted a construction line, and set its length equal to the global variable. I hate to ask this from an experienced user, but have you re-booted since you first noticed this?
And if yes, and it's still acting up, maybe change the units from Custom to IPS?
With your file, I made the line in Sketch6 ="rise" and it shows 1". What SW version are you using?
I even looked in the KB and can't find anything reported for anything similar.
2021 SP5.1
2021 SP5.1
PEBCAK?
- - -Randy Pausch
- - -Randy Pausch
- x 2487
- x 1888
That's probably it...In a Zoom meeting now, but will try that. It's been a while since I've rebooted.Glenn Schroeder wrote: ↑Fri Aug 26, 2022 9:32 am It worked fine for me. I started a new sketch, inserted a construction line, and set its length equal to the global variable. I hate to ask this from an experienced user, but have you re-booted since you first noticed this?
- x 2487
- x 1888
- x 2487
- x 1888
Thanks for the suggestion @Glenn Schroeder. I changed from "Custom" to IPS and it fixed the problem. Still confused as to how it happened.
Stupid SW, buggy software...Are my templates now broken? I guess I'll follow up next week with a coworker and check it out.
- x 1652
- x 2058
I would definitely check them, and if they're set to Custom I'd change it to IPS.mattpeneguy wrote: ↑Fri Aug 26, 2022 11:44 am Thanks for the suggestion @Glenn Schroeder. I changed from "Custom" to IPS and it fixed the problem. Still confused as to how it happened.
