Is there a table stored somewhere in SW that can be edited for cosmetic threads (not the hole wizard ones).
Currently the standard callout for say M5 is "M5 machine threads". I would like M5 x 0.8 x 10 deep or M5 x 0.8 Thru. Or along a bar M5 x 0.8x 15 Long.
I know I can manually edit them on an individual basis.
Is there a cosmetic thread table that can be edited
- x 755
- x 907
Re: Is there a cosmetic thread table that can be edited
Well, in a design table, you can have the callout be whatever you want.
See the link below:
https://help.solidworks.com/2021/Englis ... hreads.htm
See the link below:
- x 755
- x 907
DanPihlaja wrote: ↑Tue Aug 30, 2022 12:28 pm Well, in a design table, you can have the callout be whatever you want.
See the link below:
Yeah....so apparently they don't mean callouts at the drawing level (at least in SW 2018 anyway) because that didn't work.
As for any other type of callout, I cannot figure out how to display them. The closest that I can get is to display the Minor diameter.....not the callout.
So, that whole help area seems worthless.
Sorry about that.
Edit: See comment below.
- x 755
- x 907
OK....just discovered something.DanPihlaja wrote: ↑Tue Aug 30, 2022 3:39 pm Yeah....so apparently they don't mean callouts at the drawing level (at least in SW 2018 anyway) because that didn't work.
Sorry about that.
This only applies when you set the standard to "none"
Then you can apply whatever callout you want and THEN you can configure it as well using the above method. And it works in drawings, I can attest.
Thanks, mmm I do edit that section of the cosmetic thread when I need too.
