Quadro M4000
Tapani Sjöman
x 33
x 14
Quadro M4000
Unread post by Tapani Sjöman »
I'm having some problems with Quadro M4000 with SW2022. Does anybody had also and how to solve? I know it is not supported, but it is a good card so should be doing fine still!
If I save a drawing, some views are dissapearing and now could not tick "High quality" -option on in views. It popped automatic back to "Draft quality" even if I did every trick I could. Drawing size is quite big, about 35 Mb, 3 sheets.
x 2361
x 2011
Re: Quadro M4000
Hey Tapani,
Have you tried setting the views in "Shaded with edges"? This generally makes the "High Quality/Draft Quality" setting appear for me.
If you have section views, look into your section views if they are showing the surfacic bodies. If they are and it isn't necessary, untick the settings on those views.
Tapani Sjöman
x 33
x 14
Re: Quadro M4000
Got a new workstation with Quadro RTX 4000 but the problem still exists. SW2022 SP 4.0
x 2361
x 2011
Re: Quadro M4000
Hey Tapani,
I have an RTX 4000 also, I'm not on 2022 but I've experienced the issue you're facing before.
Have you looked into your assembly to see if something isn't constantly rebuilding?
Have you used the SolidWorks Performance Evaluation tool to see if perhaps you have circular references?
Using the Performance Evaluation tool still, have you checked if your assembly contains files from a previous SolidWorks version?
Have you tried the tips I had advised in my post before?
Edit: Maybe you have this issue also:
https://forum.solidworks.com/thread/210007
