CL in Drawings - Holes Only?
Posted: Mon Oct 24, 2022 11:56 am
by m2shell
In Drawings: When I use the centerline tool, and I want to Auto-Insert centerlines at all holes in a view, I click the "Select View" checkbox. This works fine, but if my part has tangent edges in it (such as with angle iron), it will create a centerline for all the curves in the angle iron and I have to then delete them. Is there any way to set the auto-insert to only holes and not linear tangents?
Thanks
2021 SP 5.1
Re: CL in Drawings - Holes Only?
Posted: Mon Oct 24, 2022 12:11 pm
Here's what I got with these settings, using SW2022 sp 4.0. I don't know if SW2021 is different.
Posted: Mon Oct 24, 2022 12:28 pm
by Tom G
I agree with Glenn's Auto Insert settings in the Center Mark tool. Particularly, uncheck "For all fillets" to avoid the center marks upon structural member profiles.
Posted: Mon Oct 24, 2022 1:24 pm
by josh
I also agree with Glenn's auto insert settings. However, they are entirely irrelevant to your question since you're asking about centerlines and not Center Marks.
Unfortunately, there's no way to specify that only holes get centerlines.
Posted: Mon Oct 24, 2022 2:17 pm
by DanPihlaja
The auto centerline/centermark tool in Solidworks drawings has been the single most disappointing and useless thing Dassault has ever created.
Posted: Mon Oct 24, 2022 2:23 pm
DanPihlaja wrote: ↑Mon Oct 24, 2022 2:17 pm
Ummmm?
- image.png (48.73 KiB) Viewed 1127 times
Posted: Mon Oct 24, 2022 2:27 pm
by DanPihlaja
bnemec wrote: ↑Mon Oct 24, 2022 2:23 pm
Ummmm?
Well..... *deflate* ..... I stand corrected...
Posted: Mon Oct 24, 2022 2:29 pm
josh wrote: ↑Mon Oct 24, 2022 1:24 pm
I saw that, but I guess the part about wanting them in holes threw me a curve. I assumed the OP meant center marks and not center lines.
Posted: Tue Oct 25, 2022 9:37 am
by m2shell
Glenn Schroeder wrote: ↑Mon Oct 24, 2022 2:29 pm
Sorry. Center Lines, not center marks. I should have put in a screen-shot.
I hardly ever use center marks b/c my clients don't require them and I find it easier to snap dimensions to the actual hole. Of course now that I think of it I can always put the center marks on another layer and disable it for dims etc etc.
Thanks everyone For replying
M
Posted: Tue Oct 25, 2022 9:52 am
by m2shell
Posted: Tue Oct 25, 2022 10:10 am
by TTevolve
Ummmm?
LOL......
If you only need a few it's better to do them by hand then using auto insert because of the extra ones you get when auto inserting them. You can window and delete them, but it's still a pin in the rear.
Posted: Tue Oct 25, 2022 10:38 am
by m2shell
TTevolve wrote: ↑Tue Oct 25, 2022 10:10 am
LOL......
Yep. P in the rear .
